IKEA Drill Battery Replacement
  1. IKEA Drill Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 4 mm Phillips screwdriver to remove the seven screws to disassemble the housing of the drill.
  2. IKEA Drill Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sticker carefully from the bottom.
  3. IKEA Drill Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the housing of the drill.
    • While opening place the rotation switch apart.
    • Detach the electric circuit and place it next to the drill.
  4. IKEA Drill Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Cut each tubing from the three wires of the battery with a utility knife.
  5. IKEA Drill Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 IKEA Drill Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the three wires of the battery with a soldering iron.
  6. IKEA Drill Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place each new tubing (three in total) on the battery wires through sliding them on each wire.
  7. IKEA Drill Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the two batteries to each other with tape, in case you have two separate batteries.
    • Use solder and a solder iron to attach the new battery to the wires.
    • The black wire should be connected with the negative pole of the two-wire side.
    • The wire should be warm enough to solder the battery to the wire.
    • Slide the tubings on each connection and heat each tubing with a lighter to make them shrink.
  8. IKEA Drill Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the electric circuit and the rotation switch back into the housing.
  9. IKEA Drill Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put the housing back on the drill through clicking and closing it.
    • Put the seven screws back into the housing with the Phillips screwdriver.
Emma Hoogenboezem
crwdns2935283:003/08/17crwdne2935283:0
209 crwdns2915208:0crwdne2915208:0
Delft University of Technology, Team S1-G18, Flipsen Spring 2017 crwdns2935289:0Delft University of Technology, Team S1-G18, Flipsen Spring 2017crwdne2935289:0
TUD-FLIPSEN-S17S1G18
crwdns2947412:05crwdne2947412:0
The difficult and dangerous operation is the tag connection to the Li-ion battery case. The Weller soldering iron shown in (7) has the wrong shape solder tip. The connection to a Li-ion must be made quickly and without significant heating of the Li-ion. Connections are usually spot welded but an amateur could try a solder gun.
The replacement batteries should be Li-ion size 18650 of at least 1500 mAh and identical. These are available with tags already attached and I would buy these and crimp to the tags. I have not done this myself because I found the receipt and the drill was bought 3 years ago so it is going back. The batteries were manufactured 4 years before I bought the drill so they were old when I bought it.
kaydee - crwdns2934203:0crwdne2934203:0
Anyone know where I can get new brushes for the motor? Or a motor itself? Everything else works fine on my now 12 year old drill!
Charlie Nancarrow - crwdns2934203:0crwdne2934203:0
Where I can find charging pcb?
Rahul - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 13,720
