HyperX Alloy Origins HX-KB7RDX-US Disassembly
crwdns2942287:0crwdne2942287:0This was a non-functioning keyboard, that was opened in order to expose the PCB.
crwdns2944105:0crwdne2944105:0
Remove the rubber foot from the upper right keyboard stand to expose the machine screw. Then remove the screw.
Remove all of the keys to expose the 16 black self tapping screws then remove the screws.
Gently pry the casing away from they top to expose the PCB.
Do you happen to know the pinout for the RGB light? Also, the copper trace for the space bard RGB? My RGB pad on the space bar was lifted during de-soldering to fix the stabilizer. The copper trace seems to be the most different in the space bar LED. I need to find the trace to create a new connection to the RGB for the space bar
I could probably work it out for you. It would help if you shared pictures of the lifted trace. In order to effect a repair you will need a soldering iron, solder and flux. You will also need some aircraft or kynar wire (really thin wire). Do you have a multimeter with continuity tester?
How do I get the pcb board off?
i dont know how or exactly why, but mine started to rust on the side, next to the shift and caps lock key, im going to try to remove the rust and repaint if there is any good metal sheet left after sanding
