HyperX Alloy Origins Backplate Replacement
  1. HyperX Alloy Origins Backplate Replacement, Toggle Indicator Tab: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the toggle indicator tab on the top right corner of the keyboard.
  2. HyperX Alloy Origins Backplate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the metal spudger or some other separating instrument into the right crevasse between the tab and the keyboard.
    • Lift up gently on the tab, while holding the left side of the tab down.
    • The tab can spring upwards upon removal. Eye protection is recommended during this step.
  3. HyperX Alloy Origins Backplate Replacement, Backplate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HyperX Alloy Origins Backplate Replacement, Backplate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the keyboard over so that the backplate is facing you.
  4. HyperX Alloy Origins Backplate Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber feet on the four corners of the backplate.
    • When reassembling, use an adhesive to reattach the feet. A silicone rubber adhesive is recommended.
  5. HyperX Alloy Origins Backplate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the specified keycaps as depicted in the image.
  6. HyperX Alloy Origins Backplate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all Philips #0 screws from the new openings created after removing the rubber feet and plastic tab.
  7. HyperX Alloy Origins Backplate Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HyperX Alloy Origins Backplate Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the backplate from the keyboard using your hands.
    After making enough a gap, inserting plastic cards and pushing them forcefully helped to separate the housing as there are also clips on the inside.
    shybee - crwdns2934203:0crwdne2934203:0
Mario Ricci
crwdns2935283:010/25/22crwdne2935283:0
270 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-2, Sinclaire Fall 2022 crwdns2935289:0UMass Dartmouth, Team 5-2, Sinclaire Fall 2022crwdne2935289:0
UMASSD-SINCLAIRE-F22S5G2
my plate was scratched due to being separated using a metal screw driver, do you have any recommended paints to go over the scratched areas with?
Damian Burton - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 1,392
