Huawei S10 Tablet  USB Charge Port Replacement
Harvey
crwdns2944107:0crwdnd2944107:0Harveycrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 5, 2024crwdne2944111:0
10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2944444:0crwdne2944444:0
  1. Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the cover and press the SIM card and Micro SD card in to release them both.
    • Remove the screw under the hinge cover.
  2. Huawei S10 Tablet  USB Charge Port Replacement, Remove Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a prying tool to loosen the back cover from the display.
    • There are plastic clips holding the display and back cover together, but they come apart quite easily.
  3. Huawei S10 Tablet  USB Charge Port Replacement, Remover Display Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully separate the display unit from the back cover, but not too far.
    • There is a cable connecting the two together.
    • Lift the ZIF Connector and remove the Display Cable.
    • Lay the display to one side.
  4. Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the ZIF connector to loosen the flex cable for the USB charger port.
    • It is possible the cable is glued down, sliding a flat tip underneath should be enough to loosen it for removal.
    • Remove the two screws holding the charger port in place.
  5. Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install the new charger port, Insert the cable in the ZIF connector and test to make sure it charges. Replace the screws for the USB Board
    • Insert the display into the back cover.
    • Replace the screw by the SIM card / Micro SD card slot.
    • Completed!
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Harvey
crwdns2935283:002/15/16crwdne2935283:0
6,093 crwdns2915208:0crwdne2915208:0
My s10 is not charging,if i plug it will show as if it was going to charge but it won't so what do i do in this situation
Doyin Nwakanma - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,103
