Use this guide to remove the motherboard shield carrying the fingerprint sensor in your Huawei P9 Lite.
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Twist the opening pick to lever the back cover away and loosen it from the adhesive.
When the back cover is freed from the adhesive you can pop it off by hand completely.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Use a spudger to disconnect the fingerprint sensor from the motherboard.
Peel the NFC antenna cable off of the metal plate.
