Use this guide to replace the loudspeaker in your Huawei P9 Lite.
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Twist the opening pick to lever the back cover away and loosen it from the adhesive.
When the back cover is freed from the adhesive you can pop it off by hand completely.
On the bottom of the phone remove the following screws:
Three 2.9 mm Phillips #00 screws
Four 3.8 mm Phillips #00 screws
Now you can grab the loudspeaker unit and take it out.
crwdns2935229:012crwdne2935229:0
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
dtotisitswe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same problem here. Any help?
fabio9999 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Sir hy how are you. Sir p9lite song speaker not working.
Sufyan Raja - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
