crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the old battery in your Huawei P9 Lite.
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
Twist the opening pick to lever the back cover away and loosen it from the adhesive.
When the back cover is freed from the adhesive you can pop it off by hand completely.
On the bottom of the phone remove the following screws:
Three 2.9 mm Phillips #00 screws
Four 3.8 mm Phillips #00 screws
Now you can grab the loudspeaker unit and take it out.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Use a spudger to disconnect the fingerprint sensor from the motherboard.
Peel the NFC antenna cable off of the metal plate.
Disconnect the motherboard flex cable on both ends and take it away.
Peel off the NFC antenna from the battery.
Unplug the battery connector.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$8.95
Slide the spudger under the battery at the place shown in the picture and pry it loose slowly.
When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
crwdns2935229:089crwdne2935229:0
crwdns2947412:026crwdne2947412:0
There is an extra step where you need to remove the cover of the board at the top of the phone in order to remove the NFC antenna which is not described in this guide. Better watch this https://www.youtube.com/watch?v=ADZiL7JK...
Costas Geraniou - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thanks Costas for the hint. We added the missing step.
Tobias Isakeit - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Very very thanks!
Artur - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Cercando di rimouorere l'adesivo dell'nfc si è rotto, posso assembrale il telefono senza nfc, ovviamente invalidando questa funzione?
Francesco Staiano - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Si, hai ragione: si può riassemblare il telefono senza l’antenna NFC perdendo questa funzione…
Claire Miesch - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
