Use this guide to replace the display assembly including the frame of your Huawei P9.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
First switch off your phone and remove the SIM card tray.
Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
Disconnect the fingerprint sensor using a spudger.
Unplug the antenna cable.
Remove the sticker that sits on top of the screw.
Unscrew the two Phillips #00 screws that hold the metal plate in place.
The plate, which is covering the battery connector, has two little hooks on each side. Use a tweezer to free them and unhinge the plate by carefully moving it upwards.
Now you can unplug the battery connector and bend it aside.
The EVA-L09 model has an NFC antenna adhered onto the battery.
Free the ends of the adhesive pull tabs to get a good grip on them.
crwdns2935267:0crwdne2935267:0Tesa 61395 Tape$5.99
The battery is secured with three pieces of adhesive, a removable pull-tab in the center, and on the SIM tray side. A third piece of adhesive on the button side has no pull-tab.
Pull the adhesive tabs in a slow constant movement to free the battery.
Slowly lift the battery toward the button side and free it from the remaining hidden piece of adhesive.
Remove the other five Phillips #00 screws from the motherboard.
Disconnect the motherboard flex cable as well as the power and volume button cable.
Unplug the LCD screen flex cable.
Remove the motherboard assembly.
Remove the earpiece speaker (mind adhesive underneath).
Remove the proximity sensor module from its bracket.
Carefully peel off the motherboard flex cable.
Remove the three Phillips #00 screws from the daughterboard.
Carefully remove the metal bracket. The headphone jack connector might stick to it.
Unplug the motherboard flex connector and put the cable aside.
Disconnect the headphone jack flex connector.
Unplug the connector of the loudspeaker.
Remove the daughterboard.
Pry the speaker off of the adhesive holding it to the display assembly.
Remove the headphone jack out of its recess.
Pry the vibration motor out of its adhered recess in the display assembly.
Carefully remove the fragile contact cable from the adhesive holding it to the frame.
Remove the antenna cable and the power and volume bottom cable on either side.
crwdns2935229:019crwdne2935229:0
