Use this guide to replace the loudspeaker on your Huawei P8 Lite.
Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
When all clips are open, remove the back cover from the rest of the phone.
Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
