Huawei P8 Display Replacement
  1. Huawei P8 Display Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Display Replacement, Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First switch off your phone.
    • Remove the trays for the SD card and the SIM card.
  2. Huawei P8 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Torx T2 screws located at the bottom next to the micro USB port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
    Pour ma part le Huawei P8 que j’ai démonté comprenait des vis T3 et non P2 ainsi qu’un port micro USB et non USB type C.
    Easy Repair - crwdns2934203:0crwdne2934203:0
  3. Huawei P8 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an iSclack or a suction handle to separate the display unit from the rear panel.
  4. Huawei P8 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #00 that hold down the two metal clamps covering the front camera, the display and battery flex connectors.
  5. Huawei P8 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a tweezer to remove the metal clamp covering the display and the battery flex connector.
    • Unplug the battery flex connector with a Spudger.
    • Remove the metal clamp covering the flex connector of the front camera.
  6. Huawei P8 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the headphone jack and the front camera flex connectors.
    • Remove the front camera.
  7. Huawei P8 Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four Phillips #00 screws that hold down the motherboard of your Huawei P8.
    • Unplug the vibration motor flex connector.
    • Disconnect the antenna cable.
  8. Huawei P8 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the display flex connector from the main board with a Spudger.
    • Disconnect and remove the antenna cable with a tweezer.
  9. Huawei P8 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the flex cable of the power and volume buttons.
    • Remove the liquid contact indicator that sits on top of the last screw holding down your main board.
  10. Huawei P8 Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the Phillips #00 screw.
    • Lift up the main board with a spudger and remove it.
  11. Huawei P8 Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the adhesive tape which is covering the display flex cable.
    • Loosen the adhesive around the mid frame with an iOpener.
    • In particular take care of the adhesive under the top and bottom of the display.
    • When the glue is softened you can use a spudger to get behind the display through the camera bay and get between the frame and the display.
  12. Huawei P8 Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap where you separated the display from the mid frame.
    • Insert just the tip of the opening pick and slide it along the right side to separate the display from the frame.
  13. Huawei P8 Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert another opening pick at the top of the phone and loosen the adhesive under the upper part of the display.
  14. Huawei P8 Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert just the tip of the opening pick and slide it along the left side of the phone to separate the display from the frame.
  15. Huawei P8 Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the adhesive under the bottom part of the display unit with the opening pick.
    • Flip the opening pick a little to separate the display from the mid frame.
    • If you notice that there is still some adhesive which isn't loosened, use the iOpener to loosen it and slide once more along the mid frame with an opening pick.
  16. Huawei P8 Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei P8 Display Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the display and remove it.
    • The display flex cable should easily go through the recess in the mid frame while removing the display.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
crwdns2935229:010crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
236,221 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
iFixit EU Team crwdns2935289:0iFixit EU Teamcrwdne2935289:0
Staff
crwdns2931471:038crwdne2931471:0
crwdns2935297:01,176crwdne2935297:0
Is there any difference on screen frame between GRA-L09 and GRA-TL10??? The l09 is the single sim and the TL10 is the dual sim…
Rafail Petridis - crwdns2934203:0crwdne2934203:0
installing a new screen the first time, i was looking at darkness. then, taking it apart again and taking away the protective foil on the back of the screen, it just showed pink/purple colors and started heating up pretty bad around the charging connector. my idea would be a short circuit. any idea what is going wrong and can this still be saved?
Albert Einbein - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 77
crwdns2942667:0crwdne2942667:0 18,033
