Huawei Mate 9 Battery Replacement
  1. Huawei Mate 9 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Mate 9 Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First switch off your phone and remove the SIM card tray.
  2. Huawei Mate 9 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Mate 9 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both screws on the bottom with a Torx T2 screwdriver.
    • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
  3. Huawei Mate 9 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Mate 9 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Swing open the phone to the right side.
    • Disconnect the fingerprint sensor cable with a spudger.
  4. Huawei Mate 9 Battery Replacement, Battery Disconnect: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel off the plastic sticker that holds both cables to the battery.
  5. Huawei Mate 9 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the water indicator sticker and the Phillips #00 screw beneath it, that holds the cable bracket in its place.
  6. Huawei Mate 9 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cable bracket.
  7. Huawei Mate 9 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Huawei Mate 9 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Huawei Mate 9 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
  8. Huawei Mate 9 Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Mate 9 Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
    • If the adhesive strip breaks, grab and twist it around tweezer tips a couple of times and then continue.
  9. Huawei Mate 9 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Huawei Mate 9 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $5.99
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
crwdns2935229:028crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
237,957 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,008crwdne2935297:0
crwdns2947412:07crwdne2947412:0
Danke für die detaillierte ANleitung, konnte meinen Akku wechseln und nun ist mein Handy wieder wie neu.
francisco.perez - crwdns2934203:0crwdne2934203:0
it’s almost impossible to remove the battery without damaging it!
My advice to you is to buy the LCD screen with the battery included.
madani_salar - crwdns2934203:0crwdne2934203:0
Habe es leider nicht hinbekommen - beim Versuch den Klebestreifen mit der Pinzette zu greifen hat mein Akku Feuer gefangen…
thej95 - crwdns2934203:0crwdne2934203:0
Das hat sehr gut geklappt mit der Anleitung. Danke dafür, super happy.
Im Basic Rep Set fehlte leider einer der notwendigen Torx Schraubendreher.
Andreas Rapp - crwdns2934203:0crwdne2934203:0
War erfolgreich die OP. Die Batterie war allerdings festgeklebt wie verrückt und nur sehr schwer raus zu bekommen. Musste ein flaches Messer zuhilfe nehmen, anders gings nicht. Ich hatte sie vor der Rep. glücklicherweise auf 10% entladen, damit nicht so viel passieren kann, wenn sie beim entfernen hochgeht ;-) Ist allerdings nichts passiert. Die Ladebuchse hab ich bei der Gelegenheit auch gleich getauscht, die hatte auch oft keinen richtigen Steckerkontakt mehr. Alles in Allem ca 1,5 Std. Zeitbedarf. Danke für die Anleitung.
Michael Megerle - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 27,496
