This guide details how to remove the battery from the Huawei Honor 8.
Using a heat gun or hairdryer, apply heat approximately three inches above the glass panel to warm up the adhesive around the outside edge of the phone.
Using a plastic opening tool, gently pry up a corner of the rear glass panel.
Slowly slide the plastic opening tool around the outside of the glass panel to break through the adhesive.
Gently lift the back panel off once all the adhesive has been removed.
Using a Phillips PH00 screwdriver, remove the silver Phillips 3.5 mm screw circled in red.
Using a spudger, gently lift off the small metal tab that was held in place by the screw.
Gently pry off the orange ribbon wire on the back panel.
Using a Phillips PH00 screwdriver, remove the eight silver Phillips 3.5 mm screws circled in red.
Using a Phillips PH00 screwdriver, remove the six black Phillips 4.0 mm screws circled in orange.
Using a Phillips PH00 screwdriver, remove the single silver 3.0 mm Phillips screw circled in yellow.
Using the Phillips PH00 screwdriver tip, gently scratch away the white stickers outlined in green circles to expose hidden screws.
Using a Phillips PH00 screwdriver, remove the two black Phillips 4.0 mm screws circled in green.
On my phone, the white sticker was in the bottom right corner, rather than the middle right side. However, the screw types were all the same as listed in the step above, so proceeding to remove the sticker and screws worked fine.
one of my green screws and orange screws were reversed from image, but all worked out fine, as well.
Lacking a useful magnetic pad, I made a pad of (sticky side up) masking tape to hold screws which I could mark up and it worked quite well.
Slowly slide the plastic opening tool around the perimeter of the inner lining.
Gently pull the inner lining up to remove it from the phone body.
Holding the phone so that the cameras are at the top, locate the small hole on the top right edge of the device.
Using the 0.8 mm Sim Eject tool, push down on the small hole to release the Sim Card tray.
Gently pull out the Sim Card tray and set it aside.
complete the ejection with screen facing up
and replace with screen facing up
Wenn man tatsächlich nur die Hauptkamera tauschen will, sind die Schritte 6 - 13 meines Erachtens überflüssig. Sobald der innere Rahmen abgenommen ist, kann man die Kamera von der Hauptplatine lösen (= Schritt 14).
In the following steps you will disconnect the five connectors circled in red holding the motherboard in place.
Gently pull the small ribbon connection between the battery and motherboard upward to disconnect it.
Use a spudger to gently pry off the small antenna cable on the right side of the motherboard.
Was ist das genau für eine Antenne? Habe sie eben aus Versehn abgerissen und trotzdem einfach zugeschraubt und sämtliche Funktionen (WLAN, Mobile Daten, GPS) sind noch in Takt.
Bei mir ist es so wie bei Ferdinand (Anschluss hat sich vom Board gelöst, dennoch scheint noch alles intakt zu sein. ). Ich würde behaupten, dass es extrem wahrscheinlich ist den Anschluss beim entfernen dieses Kabels abzureißen, deshalb würde ich empfehlen, den Schritt entweder auszulassen oder das Kabel am anderen Ende zu entfernen (dort sieht der Anschluss stabiler aus). Wenn man den Schritt überspringt, muss man natürlich noch vorsichtiger bei der Entfernung des Akkus sein.
Using a spudger, gently pry up the small connection that holds the motherboard in place.
Using a spudger, gently pry up the connector near the left edge of the motherboard.
Use a spudger to gently pry off the small connection on the far left edge of the motherboard.
Use a spudger to pry up a corner of the motherboard.
Lift the motherboard to remove it from the body of the phone.
Using a spudger, pry off the small connection between the speaker and phone body located near the bottom of the device circled in red.
Gently pry up a corner of the speaker using a spudger.
Lift the speaker up and out of the phone body.
Insert the plastic spudger into the gap between the frame and the battery.
Move the spudger around the outside edge of the battery to remove the adhesive.
Once all the adhesive has been removed from the battery, use the spudger and plastic opening tools to gently pry the battery away from the frame.
This is not easy. You will deform the old battery - don’t worry. Use the iOpener and guitar picks, and microwave the iOpener at least a second time half way through. I am massaging the cramps out of my fingers, but I got it.
crwdns2935229:042crwdne2935229:0
crwdns2947412:024crwdne2947412:0
Where are the battery installation and reassembly instructions?
Just go back in reverse order, Einstein
I replaced the battery on my Huawei Honor 8 and after power up it doesn’t see the SIM card. There’s no way to install the sim card tray backwards or put the SIM card in wrong. Any ideas?
Never mind. I figured it out. The metal SIM card cage got distorted and the tray was sliding in behind it, not into it. I gently bent the cage back into shape and all is well.
Do I need to apply new adhesive ? or re-use what is already on the device?
Re-using the existing adhesive worked OK, but not perfect. There’s a little gap near the volume buttons where the back separates from the inner lining. I’m using a phone case, so I don’t mind - it’s good enough that the back won’t come off while the phone is in the case.
I applied some of the adhesive strips that came with my battery kit (purchased here). Then I put the cover back on, applied some pressure and heated it up one last time in hopes that it helped the adhesive stick better.
Luke G -
Now my phone won’t even charge? Battery is in correctly and is at 60%. When I plug it in the charger connects for less than a second and then the connection disappears. Happens every time I disconnect and reconnect. Any ideas?
Im in the same boat
Done in 75 minutes, for 9€. Thanks!
the backing sticks out all stupid though
I’m sorry but at least in my case it was absolutely impossible to pry the battery away gently. There was such an amount of glue that I almost gave up. The battery bent like !&&* and two spudgers broke. i didn’t use any heat. And I think it would be important to actually show te reassembly because at least I don’t have any idea how much and what sort of glue should be used at any given point. I used B-7000 because that was my best guess.
Super Anleitung, super Repairkit. Hat alles so funktioniert wie beschrieben.
Tried to change my battery. Made it to the battery without serious injury. Cut the LCD cord. Q-Q
90% of this was just trying to pry the case off and the battery off. The glue is very tough. For the case, at the beginning I would suggest using a heat gun/hair dryer for a single corner first for a few minutes until you can pry it open a bit and wedge something in there. Then heat up the sides for 30 seconds as you run along the sides with plastic to break apart the glue. I also made really good use of the suction cup tool for this part. For the battery, I ended up using a plastic card to wedge underneath and break the glue at the very end because my little wedgers that look like guitar picks that came in the basics kit were too short.
198/5000
To detach the battery, I recommend proceeding with the tool on the perimeter of the battery and do not insert it underneath. I broke the flat cable by inserting the tool under the battery, (over half)
Thanks for the tutorial, but it seems to me that it’s a bit of a hassle for nothing. Steps 9 - 16 were totally unnecessary (you can already detach battery and stick new one in without having to detach motherboard ?) and you could probably skip the unscrewing of step 4 (17 screws) by just unscrewing the one that is holding battery connection down, lifting it up gently with the spudger while swapping batteries.
I used a new battery on my honor 8. Is 68% and now the phone not charging. Who is the problem
Schade dass die abstehende Lasche / Kupferfläche am Displaykabel nicht erwähnt wurde, sie ist bei mir leider beim heraushebeln des Akkus abgerissen - mein Handy ist jetzt Schrott. Danke!
Nicht unbedingt. Man kann ja auch den Bildschirm tauschen. Kostet 40€
da braucht man keine mainboard zu entfernen zum akku tausch akku tausch in 15 min !! warm machen alkohohl unter den akku mit leichten zügen entfernen neuer rein fertig !
There is no sound on incoming calls. Possible causes & can it be fixed?
Why the need for steps 5-15? Battery will come out after removing the mid frame.
hi during replacement of battery on my honer 8 mobil i managed to brek one of the to cables the one on the left side on the screen .I am wondering if its possible to order this par or the hole screen .part nr ?
Regards
Rai
When I reverse the order to close the back side, would it hold with the old adhesive? if not, how do I keep it from falling?
yaniv feinberg - crwdns2934203:0crwdne2934203:0
