How to reset the password on a Mac
  1. How to reset the password on a Mac, Start your Mac in Single-User Mode: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down your Mac
    • Press and hold the Command + S keys while pressing the power button to turn on your Mac.
    • It is best to start holding the keys before the screen turns on or you hear the startup chime. If you see the Apple logo, then you need to shut down and to do this step over. Except on a Mac with a T2 chip, the Apple logo will always appear the second the computer turns on.
    • You should see a black screen with white text.
  2. How to reset the password on a Mac, Mount root device as read-write: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the text stops, you should see a line that says "localhost:/ root#" at the bottom. If you don't see "localhost:/ root#", press enter.
    • Type in "mount -uw"
    • Some more text will appear on the screen. when you see the "localhost:/ root#"at the bottom, continue to the next step
    Es funktioniert mit
    mount -uw /
    Theo Wintwer - crwdns2934203:0crwdne2934203:0
  3. How to reset the password on a Mac, Remove the .AppleSetupDone file: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Type in, "rm /var/db/.AppleSetupDone" and press enter/ return
    • This is case sensitive!
    • There must be a space in between the rm and / otherwise you will get a "no such file or directory" error
    • This method WILL NOT work if FileVault is enabled on the startup disk.
  4. How to reset the password on a Mac, Override root/wheel for /var/db/.AppleSetupDone: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you get a message that says "override r------- root/wheel for /var/db/.AppleSetupDone?", type in "y" and press enter/return.
    • You may get an error that says, "rm: /var/db/.AppleSetupDone: read-only file system.
    • If you don't see a message that says "override r------- root/wheel for /var/db/.AppleSetupDone?", then continue to the next step.
    How to fix this error? You may get an error that says, "rm: /var/db/.AppleSetupDone: read-only file system.
    UNITED MUSLIMEEN - crwdns2934203:0crwdne2934203:0
    Sometimes if you start over, it will work but you may be getting the error because you are using a Mac with a T2 chip and it won’t work on Macs with a T2 chip because the T2 chip does not allow write access to the drive.
    Elijah - crwdns2934203:0crwdne2934203:0
    same error, and I found a fix
    If you receive it, it means that this command hasn’t worked: “mount -uw / “
    In my case, I only typed “mount -uw” and hit enter, but you MUST type it all:
    mount -uw /
    including the space and /
    this fixed it for me and I was able to remove the setup file and proceed as described here
    mariya - crwdns2934203:0crwdne2934203:0
    I type mount -uw / but still got the error "rm: /var/db/.AppleSetupDone: read-only
    how can I fix it? I need to reset my imac
    70sunkisses - crwdns2934203:0crwdne2934203:0
    Okay, I figured out a method:
    Type mount -uw / with the space and the slash. Hit return.
    Type mount -uw again with no space nor slash. Hit return.
    Then type rm /var/db/.AppleSetupDone and hit return.
    The only time text will appear is when you type the second line. After the AppleSetupDone line, you shouldn't even have to type Y and then hit return. In fact, nothing should happen.
    If you still can't, type fsck -fy and hit return. This will check your startup volume.
    lyonmissions - crwdns2934203:0crwdne2934203:0
    you’re clutch! thank you! it worked lol
    Willy Avila -
    This one worked for me. Until I hit another roadblock stating that this computer remotely administered by Hudson Pub School. This 2nd time I did not login into my Wi-Fi during setup and it let me create a new admin acct that only I controlled. Now to delete Hudson Pub Schools.
    Paul Paul - crwdns2934203:0crwdne2934203:0
  5. How to reset the password on a Mac, Reboot computer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Type in "reboot" and press enter/return.
  6. How to reset the password on a Mac, Setup your Mac: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reset the password on a Mac, Setup your Mac: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Your Mac will now reboot to the Setup Assistant. You can now set up your Mac.
    After step 6, it reboot and going to normal window to enter password rather new admin setup page.. What could be the problem here?
    Ranjith Kumar - crwdns2934203:0crwdne2934203:0
    Did you see a read only file system error when typing in “rm /var/db/.AppleSetupDone” in single user mode?
    Same problem and i did not get a read only
    Brooke Paeper-Archuleta - crwdns2934203:0crwdne2934203:0
  7. How to reset the password on a Mac, Congratulations: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to reset the password on a Mac, Congratulations: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You have now created a new user account with full administrator access. All the user accounts created prior to this remain untouched.
You have now successfully created a new administrator account on your Mac.
crwdns2935229:022crwdne2935229:0
Elijah
crwdns2935283:012/16/18crwdne2935283:0
1,328 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
What are the steps to overcome the error?
“You may get an error that says, rm: /var/db/.AppleSetupDone: read-only file system.”
dhinostroza - crwdns2934203:0crwdne2934203:0
This error can be caused because FileVault is enabled or that there was some random error. Try running the same commands in Terminal in the macOS recovery partition and see if that works. This error may also occur on a Mac with a T2 chip. If FileVault is enabled, you will have to erase the hard drive/SSD and reinstall macOS if you forgot your password.
Elijah -
i get no such file or directory why ???
Mohamed Barnoussi - crwdns2934203:0crwdne2934203:0
El nuevo usuario administrador que se crea ¿de dónde toma el nombre “Admin” que es el nombre del nuevo usuario administrador?
Horacio Gáñez
Harok Hga - crwdns2934203:0crwdne2934203:0
: /var/db/.AppleSetupDone: read-only file system.",
you have to allow write access to the filesystem,
but only after checking for errors.
On my old MacBookPro, it's written in the system messages:
/sbin/fsck -fy
/sbin/mount -uw /
Afterwards, it worked as described
Walter Bastanier - crwdns2934203:0crwdne2934203:0
Hola, crea un nuevo usuario pero las cuentas antiguas se puede acceder sin ingresar el Pasword?
kilian figueras - crwdns2934203:0crwdne2934203:0
Remember, when mounting the drive, you actually mount two drives: the first one you mount is the root drive. The second one is the actual boot drive.
First mount the root drive mount -uw /
Second mount the boot drive mount -uw
Then you can remove the file, but I would recommend using rm -R instead of just rm. This will prevent the error.
Jadon Lyon - crwdns2934203:0crwdne2934203:0
And to add to that, the var folder may be located in /private/var, so you will may need to type rm -R /private/var/db/.AppleSetupDone.
Jadon Lyon -
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 135
crwdns2936753:030crwdne2936753:0 589
crwdns2942667:0crwdne2942667:0 44,912
