How to reset Ryoby OP40401 40V 4AH Battery Pack
  1. How to reset Ryoby OP40401 40V 4AH Battery Pack, How to reset Ryoby OP40401 40V 4AH Battery Pack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To open the battery pack you need to remove the 4 screws on the bottom of the unit.
  2. How to reset Ryoby OP40401 40V 4AH Battery Pack, Remove cap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the battery pack and remove the cap covering one of the for screw.
    • Use a pointed object (such as the iFixit P2 screwdriver) to remove the cap by sticking it in the middle of the cap and lifting out. Trying to grab the edge of the cap is much more difficult.
  3. How to reset Ryoby OP40401 40V 4AH Battery Pack, Remove screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 screws using a TR10 Torx Security Screwdriver.
  4. How to reset Ryoby OP40401 40V 4AH Battery Pack, Peel off the side label: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a utility knife, peel off the top half of the label covering the charge indicator lights (or you can cut the label in half).
  5. How to reset Ryoby OP40401 40V 4AH Battery Pack, Remove the cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful to not touch the board or the terminals.
    • Note the board part number: 280487 revision Q.
  6. How to reset Ryoby OP40401 40V 4AH Battery Pack, Reset the battery pack: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a piece of insulated wire with the ends stripped to create a short between the two terminals indicated in the picture.
    • You may get shocked if you touch any other part of the battery pack while inserting the two wire ends into the terminals.
    • After a few seconds the 4 lights will turn on: the battery pack is now reset.
crwdns2935229:05crwdne2935229:0
Emme
crwdns2935283:006/15/17crwdne2935283:0
895 crwdns2915208:0crwdne2915208:0
This guide saved my one+ 18v battery because I looked for the RST pins and shorted them for ~5 seconds to reset my battery. THANK YOU
Chris Cashion - crwdns2934203:0crwdne2934203:0
Any idea on how to reset an OP40404? The board is different. There are terminal holes in the board near the LEDs. There are two sets of terminal holes labeled GND, 3.3V, RES. There are other terminal holes but I'm guessing these are the necessary ones. I've tried jumping RES to RES, and each RES to each of the GNDs. No luck.
If I short press the button, all the lights will blink 6 times. If I long press, all the lights will come on, then the first two will come on, then only the first one will come on and blink 3 times.
Christopher Moffatt - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 95
crwdns2936753:030crwdne2936753:0 394
crwdns2942667:0crwdne2942667:0 16,743
