How to open the Huawei Watch GT 2 (46 mm)
  1. How to open the Huawei Watch GT 2 (46 mm), Remove the watch band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to open the Huawei Watch GT 2 (46 mm), Unfasten the screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.7 mm-long Torx T2 screws.
  3. How to open the Huawei Watch GT 2 (46 mm), Insert a spudger: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to open the Huawei Watch GT 2 (46 mm), Insert a spudger: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the edge of a spudger into the middle loudspeaker opening at the top edge of your watch.
  4. How to open the Huawei Watch GT 2 (46 mm), Pry up the back cover assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to open the Huawei Watch GT 2 (46 mm), Pry up the back cover assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The plastic clamps holding the back cover in place sit very tight and may require some force during the prying procedure.
    • Use the spudger to pry up the back cover assembly of your Huawei watch GT 2.
    • Don't try to remove the back cover assembly all the way yet, it's still connected to the motherboard.
  5. How to open the Huawei Watch GT 2 (46 mm): crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to open the Huawei Watch GT 2 (46 mm): crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully swing the back cover assembly open to an upward position.
To reassemble your Huawei Watch GT 2 (46 mm), follow these instructions in reverse order.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
crwdns2935229:014crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
245,362 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2935297:023,363crwdne2935297:0
crwdns2947412:05crwdne2947412:0
How can i change the battery Watch GT2 (46mm)?
Thanks for the reply!
Tamás Schmidt - crwdns2934203:0crwdne2934203:0
Hi Tamás,
the battery of the Huawei Watch GT2 is soldered to the bottom assembly cable. To replace it you're required to execute some very difficult micro soldering. The risk of damaging surrounding components is very high during that procedure.
Dominik Schnabelrauch -
hello, did you happened to replace only glass of smartwatch ?? is it posible ?? my oled and touch is working fine, but after glass unglued at corners somehow, my glass got broken. I have found that you can buy only glass for this watch.
Plewu Gracz - crwdns2934203:0crwdne2934203:0
My screen got water in and now the touch screen dont want to work.
Elmien Elmien Werner - crwdns2934203:0crwdne2934203:0
Hi, i should replace only the touch panel avoid to replace completely the display. I did not find any information or any video.
Do you have any suggestion befere approach this task ? I have no idea about the glue i have to use in reassembly of the clock.
Thanks for you answer and job
Andrea Bruschi - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 49
crwdns2936753:030crwdne2936753:0 294
crwdns2942667:0crwdne2942667:0 21,054
