How to fix Huawei P8 Lite Wi-Fi problem
francois
crwdns2944109:0crwdnd2944109:0francoiscrwdnd2944109:0crwdnd2944109:0crwdnd2944109:0crwdne2944109:0
crwdns2944111:0Sun 14, 2019crwdne2944111:0
crwdns2931273:0crwdne2931273:0
crwdns2937801:0crwdne2937801:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
Follow this guide to potentially solve Wi-Fi issues for the Huawei P8 Lite.
    • 1. go to developer options and select restore to default settings 2. in developer options ,only switch on "Developer Options " , "Stay awake" and "use legacy DHCP client" 3.Then in" Wi-Fi advanced settings" Network notifications "Off" Keep wi-fi on during sleep "Never" Set network connection method "Automatically connect"
    • this is my phones current setting and has stopped my issue
    • please comment if this has helped you with your problem
    There's no such thing as developer options on the Huawei p8 lite.
    the.stoner.kiwi - crwdns2934203:0crwdne2934203:0
    Go to your 'about phone' option in settings and press 'build number's seven times and you'll have a message saying 'youre now a developer'. Press back and above the about phone there will be 'developer options' available.
    Kiely-Lou Barnard -
    Still not connected showing access denied?
    Raja Shahraiz - crwdns2934203:0crwdne2934203:0
    How to make WiFi networks problem
    Sanjip Jayasawal - crwdns2934203:0crwdne2934203:0
    where do i get "use legacy DHCP client", can't find it unde developer mode
    gracien botima - crwdns2934203:0crwdne2934203:0
    I don't have a "use legacy DHCP client" option. Any alternative please???
    Tahrima Arani - crwdns2934203:0crwdne2934203:0
    Hi. Did you manage to locate the DHCP client? I'm having the same problem
    Meh Ni -
    Any luck here?, same problem. I don’t have that &&^&^$^ option
    Horus Rules -
    Where can I find the last step, Set network connection method "Automatically connect"?
    gboafterparty - crwdns2934203:0crwdne2934203:0
    François.... U are my hero of the day... Uhm week.... Did exactly those steps... And et voila.... Totally And utterly calm in Deventer, the Netherlands enjoying my wifi.... Fingers crossed it will stay this way.
    Thank you for your trouble and time educating me!!!!
    Mirjam Koot - crwdns2934203:0crwdne2934203:0
    ware i can find Set network connection method "Automatically connect"..
    userhuaweMY - crwdns2934203:0crwdne2934203:0
    Je ne sais pas où il faut aller dans la partie 3 merci de me répondre rapidement François car ce problème m agace cela fait quand même le deuxième HUAWEI P8 LITE que j'ai avec ce même problème. Merci
    Maxence Herbin - crwdns2934203:0crwdne2934203:0
    Under advance settings,I can't find Set network connection method "Automatically connect"
    Bright - crwdns2934203:0crwdne2934203:0
    Under advance settings, I can't find Set network connection method "Automatically connect"
    wie kann man den Netzwerkhinweis ausschalten? Bei mir ist der grau hinterlegt. Ebenfalls kann ich “Automatisches Verbinden” nicht finden.
    Boni - crwdns2934203:0crwdne2934203:0
    Wie kann ich den Netzwerkhinweis ausschalten? Der Schieber ist bei mir grau hinterlegt. Ebenfalls kann ich “Automatisches Verbinden” nicht finden.
    Can someone help for the “set network connection method”?
    Prinsha Tanakoor - crwdns2934203:0crwdne2934203:0
    Wie cool ist das denn!!!
    wollte das Telefon schon abschreiben. Genau lesen. Funktionierte tadellos!
    Dörthe Grubek - crwdns2934203:0crwdne2934203:0
    does not allow me to alter network notification……the icon is grey?
    Sinjin Skippers - crwdns2934203:0crwdne2934203:0
    i cannot access the network notification….the icon is grey?
    hola, buenas tardes cambie la pantalla del equipo y ahora no funciona el lector de memoria micro sd ni el del chip SIM-CARD, como puedo solucionarlo? muchas gracias.
    Daniel Garcia Diosa - crwdns2934203:0crwdne2934203:0
    hello, good afternoon change the computer screen and now the micro sd memory reader or the SIM-CARD chip is not working, how can I fix it? thank you very much.
    Hallo ich finde bei dem Handy Huawei p8 Lite kein Entwicklungsoptionen ich bekomme kein WLAN mehr was kann ich tun wäre sehr nett wenn mir jemand helfen kann vielen dank im voraus
    anjadarsaoui - crwdns2934203:0crwdne2934203:0
    Hallo, ich finde den letzten Punkt im Handy leider auch nicht. Das Handy verbindet sich mit dem WLAN trotzdem automatisch. Leider immer noch erfolglos. Kann mir jemand helfen? Viele Grüße
    Manuela O. - crwdns2934203:0crwdne2934203:0
    thanks my brother it worked
    milfredbm - crwdns2934203:0crwdne2934203:0
    le problème n’est pas résolue même je trouve pas “connexion automatique”
    Akrout Firas - crwdns2934203:0crwdne2934203:0
    After checking all the steps i still have IP address unavailable, what now is my phone past its sell by date. this is my first Huawei and since have got 3 others but i’m thinking its the last. Samsung here I come.
    Michael Anthony Wainwright - crwdns2934203:0crwdne2934203:0
    A me non risolve il problema
    nicola - crwdns2934203:0crwdne2934203:0
    i cant find set networl automatically please someone hepl me
    Muhammad Aqib Mohd Nor Hafiz - crwdns2934203:0crwdne2934203:0
    My Mobile wifi on but doesn't connected
    Solution?
    British Gujjar - crwdns2934203:0crwdne2934203:0
    Das Problem ist damit nicht gelöst , wie schon mehrere s. o. geschrieben haben , ist das “automatische Verbinden” nicht wählbar
    j.ott2 - crwdns2934203:0crwdne2934203:0
    Io non ho risolto.qualche altra opzione??
    lorycozzella - crwdns2934203:0crwdne2934203:0
    Il problema ( il tel lo uso solo con scheda telefonica ) e’ un chip dal costo di nemmeno 5 € che sta sulla scheda madre ( sarebbe da staccare e buttare il vecchio che funge da connettore wifi e blutooth e “ristagnare”)…ma nessuno vuole sistemarlo ( la scheda madre il piu’ delle volte lo “ ribrucia” ..colpa degli aggiornamenti di sistema..)..Queste notizie te le do perche’ ho seguito blog e articoli vari su internet…ciao Mauro
    piramids -
    I followed your instructions but it doesn’t work. Than I started cell phone again - I had the same troubles I couldn’t switch on “WLAN “ and at “Bluetooth”.
    Graz 30.8.2020
    gregor - crwdns2934203:0crwdne2934203:0
    je viens d'acheter huawei P8 lite, et le wifi & bluetooth ne fonctionne pas, est il possible d'installer une nouvelle application WiFi & Bluetooth en telechargeant sur internet?
    Simon
    Soloherilalaina - crwdns2934203:0crwdne2934203:0
crwdns2935229:063crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
francois
crwdns2935283:011/15/16crwdne2935283:0
1,775 crwdns2915208:0crwdne2915208:0
crwdns2947412:068crwdne2947412:0
ca marche pas ya t il une autre solution
sammout.rawia - crwdns2934203:0crwdne2934203:0
Admin tolong gimana wifi huawei p8lite saya kok hilang ngk?
darman ybb - crwdns2934203:0crwdne2934203:0
In Developer Options, where is "restore to default settings" and "use legacy DHCP client" ???
"" Set network connection method "Automatically connect" ": you mean Network Operators or Preffered Network Mode ???
aloalo - crwdns2934203:0crwdne2934203:0
l have problem allso my huawei p8 lite
wifi and bluetoth problem wen l turn on wifi is ok but wifi dont see konekcion also wen l go to wifi setinngs ip addrea unavailable.
can sombody help my to fix
also l tray all to fiz but nothing help.
srpskigamer 43 - crwdns2934203:0crwdne2934203:0
Same problem with me
If you will fixed it
Then
Please told me
Muhammad Wali khan Sumbal -
Me also same problem in p8 lite
If you fix it the problem plz share with me
Afroz Ahmad -
Ip address is not shown in my mobile and wifi is not turn on
Please give me suggestion and fix my problem
Afroz Ahmad -
Le même problème que je souffre s'il vous plaît si vous trouvez une solution pour m'informer et merci
Bessioud Abderrazak -
I have the same problem. Has anyone found a solution to this
Bongani Masuluke -
any solution to this?
Andre Botha -
same here. maybe a hardware problem?
Sanseghettino -
pauleenw1 - crwdns2934203:0crwdne2934203:0
Got probleme with p8 Huawei phone WiFi is not connecting were can I find the development option on the phone must I go to my settings . please I need help urgent .
Bokkie Van Zyl -
Wifi and Bluetooth problem
Rajanrai - crwdns2934203:0crwdne2934203:0
Salam wafi on nain ho jb ke sim deta chal ra ha keya prblm ho sakte ha
Zee Malik - crwdns2934203:0crwdne2934203:0
huawei p8 lite cant turn on wifi and bluetooth...way???
pongalong - crwdns2934203:0crwdne2934203:0
I have that's problem why not WiFi and bluetooth not opened reply me
Muhammad Naseem -
Send me screen shot because I not found developer option plz send me urgent or if you automatically solve my problem so solved it
Muhammad Naseem -
Huawei p8 lite can't turn on WiFi and Bluetooth also so what problem
Ali turi - crwdns2934203:0crwdne2934203:0
p8 lite cannot connect wifi it shows "network access denied" so please help me it cannot connect wifi help me what problems occur
amxah - crwdns2934203:0crwdne2934203:0
Hi. Did you have any luck with the wifi problem?
Meh Ni -
bt my wifi problem is not solve ...
sandeep bains - crwdns2934203:0crwdne2934203:0
ip address is not show on my phone wifi....whn i connect any wifi network thn wifi is not working and not connect..jst show save network ...tell me wha i do ?
The same problem I thinnk it's hardware not a software
Mighri hatem - crwdns2934203:0crwdne2934203:0
that’s right i was replace motherboard huawei p8 when my phone on 7 months old because my wifi not connection
Zahroh R J A -
Je n'arrive jamais à connecter c'est je m'éloigne d'un mètre de mon retour wifi,j'ai essais de restaurer j'ai essayé plusieurs méthodes sans résultat,dites moi ce que je dois faire avec ce p 8 lite????
Karimou - crwdns2934203:0crwdne2934203:0
Hi all!
If anyone have problem with wifi on Huawei smartphone can watch this video link below and i hope to fixed, worked for me…
https://www.youtube.com/watch?v=u6OSlvDm...
Shkodran Berisha - crwdns2934203:0crwdne2934203:0
Not working . Please i need help
Cristiano - crwdns2934203:0crwdne2934203:0
I have a solution if u want sent me mail yanzerose@outlook.com
Nirajan - crwdns2934203:0crwdne2934203:0
Hi Nirajan, i’ve send an mail to you, please help
rakotomihamina andry -
I have the same problem but came across a solution that might work for you. For bluetooth put your phone in flight mode and switch on bluetooth. For wifi you should remove your media card that could be damaged.
Fire Fly - crwdns2934203:0crwdne2934203:0
Hi
I am bilal. I have Huawei p8 lite. My mobile phone have not working WiFi , Bluetootha and hotspot. I have many problems. Please ask me Answer what can. I do?
Bilal Younas - crwdns2934203:0crwdne2934203:0
I have same problem with my Huawei p8 lite.
Wifi and Bluetooth not turning on, for 5days now. I've tried different options, but problem remain the same, can anyone help me??
INNOVATION TheReasonWhy - crwdns2934203:0crwdne2934203:0
belom bisa.. uda di ikutin semua cara di atas.. hp saya dari telestra.. wifi bisa di nyalakan namun tidak mau konek
masirvan - crwdns2934203:0crwdne2934203:0
My phone doesn't want to switch on Bluetooth and WiFi what must I do
Christopher - crwdns2934203:0crwdne2934203:0
Respected sir in My phone Network Notification has beeb stuck please tell me what to do plz ????
Ali Hamza Tariq - crwdns2934203:0crwdne2934203:0
I cannot find. Developer mode , and. Leagacy and network connection automatically kindly guide via Screenshots. Tht will be more helpfull
Muhammad Khird Added - crwdns2934203:0crwdne2934203:0
por favor mi p8 lite no me funciona wifi ni bluetooth, me pueden colaborar?
j.andres.08 - crwdns2934203:0crwdne2934203:0
ya realice lo de opciones de desarrollador, pero no se que mas debo hacer?
My phone same problem i cant connect on wifi how can i fix it
Anntotz Gabriel - crwdns2934203:0crwdne2934203:0
did any body solve the wifi problem on the P8
constant - crwdns2934203:0crwdne2934203:0
my huawei ale-lo2 dosnt have "use legacy DHCP client
lancelin3 - crwdns2934203:0crwdne2934203:0
tried everything wifi is still greyed out same as blutooth can anyone help ??
No wifi and Bluetooth help me please
Karla Thomsen - crwdns2934203:0crwdne2934203:0
WiFi Bluetooth Repair - HI1101 WIFI IC wi-fi Module chip For Replacement Huawei P8 P8 lite: http://got.by/2qj6am
egilaval - crwdns2934203:0crwdne2934203:0
WTF This happen to both Huawei Phones that I have… If this solution doesnt work… Hardware Issues maybe
Just buy another phone..
Never buy Huawei Phone Again…
Martina Martins - crwdns2934203:0crwdne2934203:0
Hi! Where can I find the network connection method? I have done all the steps except the last one since I was unable to find the netowrk connection method options. Thank you
Marie Rowenna Brusola - crwdns2934203:0crwdne2934203:0
It seems that many people are sharing the same problem, I suggest to ask the manufacturer to collect the cellphones and change the wifi/GPS antenna
Ghassan Kattoua - crwdns2934203:0crwdne2934203:0
After i went through all the steps i still cannot connect to my wifi.
Shaun Stuurman - crwdns2934203:0crwdne2934203:0
Hello, my smartphone is Huawei P8 Lite too, and 7 months old, I experienced WiFi not connected because I went and I went to a Huawei service counter and the official replaced the motherboard device. and my officer said that the wifi problem was indeed a weakness of Huawei P8 Lite. and now after 2.5 years my phone has experienced the same thing again, while to replace the Huawei p8lite motherboard the price is quite expensive, buying a new smartphone is the solution.
Zahroh R J A - crwdns2934203:0crwdne2934203:0
Mon huawei P8 lite 2017 active bien le WiFi Direct … mais quand on veut l’utiliser, un message qui reste à l’écran 1/4 de seconde indique que pour l’instant, seules les échanges avec d’autres appareils huawei sont autorisées. et bien sûr, bien qu’on arrive sans aucun problème à établir la connexion avec d’autres appareils, comme mon Samsung, toute utilisation du transfert entre les deux machines échoue. bravo leur conception deu monde “OPEN” d’Androïd !!!
Boizot - crwdns2934203:0crwdne2934203:0
MY phone is conntecting and disconnecting randomly. Through out a single second.
faizanakhter110 - crwdns2934203:0crwdne2934203:0
Do not off network notification
Mohd Kifa - crwdns2934203:0crwdne2934203:0
Ces ou qu'on trouve les options développeurs sur la p8 lite
Hadiatou Barry - crwdns2934203:0crwdne2934203:0
J ai le même problème je n'arrive pas a me connecter sur le wifi . Ça me fait connections enregistrer et cripte
my p8 lite doesnt show developer options
Andre Botha - crwdns2934203:0crwdne2934203:0
Meme probleme sur portable acheté d'occas pour noel a mon fils. Je suis dégouté de mettre fait avoir !!!
sophie.mainguin - crwdns2934203:0crwdne2934203:0
This fix worked for me. I could not do the last instruction (Set network connection method "Automatically connect") because there is no such setting for my version, but it solved the issue anyway :) Thank you!
Horazon - crwdns2934203:0crwdne2934203:0
Huawei P8 Lite, ALE-L21, Dual SIM Wi-Fi a szobában működik. A konyhában jó jelerősség van minden hálózati hozzáférés, megtagadva üzenet fogadására. Szia. Tamás
tamas aradi - crwdns2934203:0crwdne2934203:0
I have a problem when I turn WiFi on and put in the password … it says saved,secured …but there is no connection after that … what can I do to solve the problem
keanon frederick - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 360,668
