How to disconnect the battery in the GuliKit KingKong 2 Pro
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. How to disconnect the battery in the GuliKit KingKong 2 Pro, Unfasten the back cover screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 11 mm-long screws securing the back cover.
  2. How to disconnect the battery in the GuliKit KingKong 2 Pro, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The back cover of the GuliKit Kingkong 2 Pro is held in place by plastic clips.
    • Insert an opening pick into the gap between the front assembly and the back cover at the bottom edge of the controller.
    • Tilt your opening pick downwards to widen the gap.
  3. How to disconnect the battery in the GuliKit KingKong 2 Pro, Separate the front assembly and back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Separate the front assembly and back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the right controller handle.
    • Slide the opening pick along the gap to separate the front assembly from the back cover.
  4. How to disconnect the battery in the GuliKit KingKong 2 Pro: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick into the gap between the front assembly and the back cover at the outside of the left controller handle.
  5. How to disconnect the battery in the GuliKit KingKong 2 Pro, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Remove the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the back cover from the front assembly and remove it.
  6. How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the right vibration motor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the right vibration motor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the right vibration motor: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It's not mandatory to remove the two vibration motors to remove the mainboard assembly. However, other repairs become much easier with the motors removed. If you want to leave the motors in place, you can jump straight to step 9.
    • Pull on the connectors themselves and not the cables to avoid damaging them.
    • Use the point of a spudger to disconnect the right vibration motor by pushing the connector straight out of its socket.
    • If you can't disconnect the vibration motor with a spudger, use a pair of blunt nose tweezers to pull the connector out of its socket.
  7. How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the left vibration motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the left vibration motor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the left vibration motor: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to disconnect the left vibration motor by pushing the connector straight out of its socket.
  8. How to disconnect the battery in the GuliKit KingKong 2 Pro, Remove the vibration motors: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the vibration motors by lifting them out of the controller housing.
  9. How to disconnect the battery in the GuliKit KingKong 2 Pro, Release the interconnect cable ZIF connector: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Release the interconnect cable ZIF connector: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  10. How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the interconnect cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the interconnect cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nose tweezers to disconnect the interconnect cable by pulling the cable straight out of the connector.
  11. How to disconnect the battery in the GuliKit KingKong 2 Pro, Unfasten the mainboard assembly screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the screws securing the mainboard assembly:
    • Four 7.8 mm-long screws.
    • Two 11 mm-long screws.
  12. How to disconnect the battery in the GuliKit KingKong 2 Pro, Remove the mainboard shield: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Remove the mainboard shield: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nose tweezers to remove the metal shield from the mainboard assembly.
  13. How to disconnect the battery in the GuliKit KingKong 2 Pro, Remove the mainboard assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Remove the mainboard assembly: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Remove the mainboard assembly: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mainboard assembly by lifting it out of the controller housing.
  14. How to disconnect the battery in the GuliKit KingKong 2 Pro, Unfasten the battery frame screw: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take care not to puncture the battery with your tool—a punctured battery may leak dangerous chemicals or cause a fire.
    • Use a Phillips #00 screwdriver to remove the single 7.8 mm-long screw securing the battery frame.
  15. How to disconnect the battery in the GuliKit KingKong 2 Pro, Free the battery frame: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Free the battery frame: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Free the battery frame: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Free the battery frame by lifting it off the plastic pins holding it in place.
  16. How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the battery: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to disconnect the battery in the GuliKit KingKong 2 Pro, Disconnect the battery: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nose tweezers to disconnect the battery connector by pulling it straight out of its socket.
    • Remove the battery and its frame from the controller housing.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
237,718 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,981crwdne2935297:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 41
