Hi there! As someone who was not to familiar with unscrewing things and always being afraid of messing things up, this was the very first thing I successfully did in order to improve my MacBooks life. And guess what? It wasn’t as scary and complicated as I thought it would be. It’s a super easy and uncomplicated task and it’s totally doable once or twice a year. Over time there’s usually quite some dust inside of your MacBook and keeping it clean can prevent overheating and keep your Mac running quiet and smoothly. Once you’re done your MacBook will be super happy and forgive you for keeping it in your bed a few (or many) times. It’s a fresh start for both of you! All you need is some space on a desk, a P5 Pentalobe screwdriver, a cleaning cloth, maybe a hair dryer (or strong lungs, if you want to blow yourself) and some sort of (clean!) little brush. Let’s go!
So you want to clean the inside of your MacBook to make sure your fan is not suffocating from all the dust that floating around - great!
After making sure your device is turned off, your first step is turning it around, thank god that's an easy one!
Next thing: take your P5 Pentalobe screwdriver and unscrew the screws. That's also quite easy, you'll see!
Put them nicely around your MacBook to remember where they are or put them somewhere where you won't lose them!
Now that you've unscrewed your screws, you can open up your Macbook. Start from the top and (gently!) try to loosen the case. It might take a couple of tries, but you'll be able to do it - promise!
I KNEW YOU COULD DO IT!
Gently pull the case up and there you'll see it...
For anyone who has a 2020 13inch MacBookPro, this can be a little difficult. It took me hours to get it, but I finally found this video and it really helped.
I also got this little cleaning kit from Amazon. Use the star screwdriver and when the guy says use a thin piece of plastic, use the flat edge of the black thingy that isn’t the brush (I feel a little dumb for taking so long to realize what it was for, so humor me and pretend you wouldn’t have known either).
... A DUSTY OLD MACBOOK! How horrifying. Good thing you're here and want to clean up.
Let's start cleaning. Take your soft wet cloth and gently clean the dust of the case. You'll see quite the difference.
crwdns2935267:0crwdne2935267:0Electronics Cleaning Bundle$23.99
When you are like me and you don't have super fancy equipment, take a hairdryer or use your lungs and softly blow the dust away. If you use your hair dryer, make sure you're using a cool mode and a low level. iFixit also offers a dust blower that you could use!
Now's the time to use your little brush and get into cleaning. Number one rule is being gentle and not using too much pressure. If you have a microfiber cloth that might come in handy as well.
You can easily take that black rubber thingy off your fan to get into all the corners with your brush (I hear they call that thing 'rubber fan bumper' - what a word).
When you've loosened the dust, just take the hair dryer again and blow it away.
Now you need to be extra careful, cause we want to clean the fan. Put one of your finger in the middle of the fan so it can't turn anymore. Take your brush and gently try to loosen up the dust particles with the bristles of the brush.
This might take a while but you'll see that there's quite a lot of dust hidden in that fan.
Gently blow the dust away once it's out of the fan.
Now that is one good lookin' old MacBook, don't you think?
Can you spot the difference?
Put that little plastic thing back in place.
Take a look at the freshly cleaned insides of your MacBook and pat yourself on the shoulder.
Put the case back in place.
To reassemble everything, put the case back on and push gently until you hear a soft click. Take your little screws and screw them back into their place. Make sure everything sits tight. Now that your MacBook is still off, it might be worth also cleaning the display and keyboard with a soft cloth… when your done, just turn your MacBook on and feel good about yourself!
crwdns2935229:057crwdne2935229:0
crwdns2947412:029crwdne2947412:0
shall I use electric circuit cleaner spray on the fans?
Hey there :) I am actually not quite sure cause I haven't tried that but my initial thought would be that any sort of fluid could cause damage when you can't 'wipe it out' after spraying on something. The liquid could combine with the dust and clog the fan.
why would you lie and say this was easy ?
I am very sorry if you experienced any difficulties! With which part did you struggle?
Thank you for the clear example of cleaning a MacBook Pro. I feel confident I will be successful!
Absolutely loved your guide - thank you. Informative, easy and amusing. My son and I completed it easily (once we had the right screwdriver). Saved us a ton of cash so thank you very much.
Hey Gillian :) Thank you so much for your nice feedback and I'm glad to hear that you completed it easily! Wishing you and your MacBook all the best.
This was really helpful. As an addition, please note that the backplate slides (!) off, gently pull it towards you in the horizontal plane (so not vertically!). Thanks for the pics and instructions!
Glad it was helpful! And thanks for the advice :-) Feel free to just edit the step and add your note to the step. Together we can all create the best guides after all!
hello! jjust wanted to tel you that you are a nerd
thanks for the essayt tough i was very helpful
I was a little apprehensive about cleaning my MacBook but, thanks to you, it was a breeze and is now back to being quiet. I appreciate your detailed descriptions and general tone. Thank you!
Is the brush in the Electronics Cleaning Bundle different from the Anti-static brush?
Should I blow with a hairdryer, as suggested, or would a vacuum cleaner with a soft brush also work? Then the dust is not distributed throughout the apartment.
It was a bit fiddly getting the cover off, but did it in the end. Cleaning out the dust has made a big difference to cpu temp!
Thanks for this tutorial. Even without any experience, it was very easy. But when I opened my MacBook Pro 13'' mid 2009 I saw that there was only very little dust inside even though I've been using it for 14 years, also in not very clean conditions, without cleaning it before. Conclusion: Depending on your laptop model, not much dust is getting inside, in which case there won't be a need to clean it for many years, since cleaning also bears a small risk of damaging e.g. the fan.
FYI do this with gloves. The back cover is very sharp on the edges. When I went to the final step to remove it, it sliced about 1/3 of the way through the tips of 2 of my fingers. I ended up at the ER and don’t have sensation anymore in one fingertip, it will probably never come back.
"....maybe a hair dryer (or strong lungs, if you want to blow yourself)"....Thank you I tried to blow myself, but I'm not flexible enough.😁
You did a great job, I am in my last year of my 2nd degree and my MacBook air is really overheating. I'll clean it up as I can tell the overheating is coming from the fan area. Thank you for your work!
Thank you so much for this tutorial...
Just in case...if my fan gets damaged, can it be replaced? I will try this as I am extremely skeptical of leaving my mac w anyone
after tech causing irreprable, never mind security issues.
Thank you so much for this tutorial ...
Just in case...if my fan got damaged, could it be replaced/repaired?
Extremely skeptical of leaving my mac w a tech as last mac was rendered irreparable
and out of business for weeks...first w apple support and then certified local apple tech. ...and then..there is security.
I was looking for the same kind of info for cleaning MacBook. Thanks for sharing.
Note that the longer screws go nearer the hinge and the shorter ones only require about 2 rotations. I had to drill one of the screws, because I stripped the head getting it out. Maybe Apple glued it !! Anyway thanks there's enough screws even with one missing. .
thanks so much for adding this !
Michelle -
Hello. Thank you for the guide as I will soon clean my macbook. Question: the fan looks like it is enclosed, will using compressed air or a blower completely remove the dust? Will dust not go further into the fan "housing"? Thanks.
Is this process going to void product's warranty? No right? And, Is it fine if I vacuum the dust instead of sweeping it off, and I keep the fan still with my finger? My Mac is 14" 2021 MacBook Pro with M1 Pro.
kann ich das auch bei Mac Book Pro 2021 mit M1 chip machen ? ( 14 inch ) oder nur bei einem älteren ? bei meinem sehr alten Macbook früher hab ich es immer selbst gemacht (das war aber noch sehr robust und dick ) ; aber bei dem neuen trau ich mich nicht so recht . Was ist deins für ein Modell ? sehe es auf dem Foto leider nicht so genau (auch mit Vergrösserung ) ; danke ! :) Michelle
I´m not sure in which language I´m supposed to comment :) Can I do this with my Mac Book Pro 2021 with M1 chip ? (14 inch ) or does this only work with older models ? With my macbook 2 generations back I did clean the fans myself but with the new model I´m a bit scared ....Sadly I can´t make out the model of your macbook on the photo (even though I amplified the photo ) ; any comments on this ? thanks everybody ! Michelle
This was really easy and straight forward, thank you so much! I was afraid it will be hard, as it was my first time.
