How to clean the Nintendo 64 cartridge slot
  1. How to clean the Nintendo 64 cartridge slot, How to clean the Nintendo 64 cartridge slot: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the slot with your finger. Blow along the length of the cartridge slot with the air duster.
  2. How to clean the Nintendo 64 cartridge slot: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Moist a q-tip with rubbing alcohol. Rub it along the length of the cartridge slot.
    I never knew about this step, up until now i was just doing step one
    Mike Chang - crwdns2934203:0crwdne2934203:0
    Alcohol is not going to "shine up" the pin. The secret will take 10 seconds!!!!. A worn out paper fingernail file .. I have never had a console brought back in 2 yrs
    thegamestorems - crwdns2934203:0crwdne2934203:0
    What type brand of fingernail file?
    Bresee -
    Nice idea-- i was wondering what would fit in there between the contacts and not be too stiff so as to break anything but still offer just enough resistance and abrasion. I will surely give this a try.
    Kevin K -
If cleaning the cartridge slot worked, you should be able to insert a game and play normally. If the game still does not boot normally, check to make sure the pins are not damaged, and that the cartridge does not need cleaning.
crwdns2935229:029crwdne2935229:0
tonymag28
crwdns2935283:010/28/09crwdne2935283:0
2.249 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-4, Regan Fall 2009 crwdns2935289:0Cal Poly, Team 5-4, Regan Fall 2009crwdne2935289:0
CPSU-REGAN-F09S5G4
crwdns2931471:07crwdne2931471:0
crwdns2935297:020crwdne2935297:0
crwdns2947412:014crwdne2947412:0
Oh, my God! I really didn't think the alcohol thing would work (actually, I thought it was going to scr#w my nintendo), but it did! Thank u so much!
silvestrerenata - crwdns2934203:0crwdne2934203:0
I'm a Iittle skeptic to use rubbing alcohol on my N64 system and games are you 100% sure it works and won't give me any problems downs the road.
James Hernandez -
You should use isopropyl alcohol, it’s 90% alcohol and drys very quickly. I usually dunk a q-tip in, tap it against the bottle to remove any excess, then clean the surface. As long as your not pouring the alcohol directly onto your electronics you’ll be fine.
Adam -
This works because water and other liquids contain minerals that are conductive, thus, by having it on a running electronic device, it will cause a malfunction/short, whatever you call it, HOWEVER, if the device is off, no electricity is flowing, thus the rubbing alcohol does what you want it to, and removes all the dirt and grime preventing your games from playing..
Bloxy -
Alcohol will not remove the tarnish on the brass pins in the console. A paper fingernail file
Up & down back & forth 1 time. Have 500 consoles in store. 8 1/2 years never had a cartridge system ever come back toy store. Takes 5 seconds & cost a nickel.
Michael - crwdns2934203:0crwdne2934203:0
Can you please explain how you do it? What materials are you using. Sorry but english is not my native language.
Andres Corona -
Wow, this tip just saved my n64! Thank you
Michael P -
Hi, my N64 keeps crashing- will cleaning these pins stop that? Is this a common cause of this problem? Thank you.
semloH -
I just rub some 99% ipa on a game’s pins and jam it in and out of the console like 5 times. Works like a charm.
Matt V - crwdns2934203:0crwdne2934203:0
Micheal,
I really like your comment, “Alcohol will not remove the tarnish on the brass pins in the console. A paper fingernail file Up & down back & forth 1 time. Have 500 consoles in store. 8 1/2 years never had a cartridge system ever come back toy store. Takes 5 seconds & cost a nickel.” I would like to buy a paper fingernail file, is there one on amazon you could recommend?
Charles Runyon - crwdns2934203:0crwdne2934203:0
What if I don't have an air compressor?
Matthew K. - crwdns2934203:0crwdne2934203:0
Air compressor, whether in a can or a bottle rocket, is very useful for cleaning the cartridge slots, because it gets dust out of the nooks and crannies. I usually use the spray nozzle on my IPA bottle and then the air compressor to blow the IPA into those little nooks, as well as the cotton bud technique. Compressed air is easy to get hold of on Amazon. The Giottos Air Blaster is what I use. Don't be tempted to blow air from your mouth, of course.
DrillbitNights -
IPA that is 90% purity or higher - mine is 99.9% - has such a low water content that you really don't need to panic about shorting things out. It dries incredibly fast, so unless you're a bit stupid or careless and pour a great glug of it onto the console for whatever daft reason and immediately power it on, it won't cause damage.
Just be wary of getting it on materials (it'll bleach them), or onto any open cuts (it's dangerous). To be on the safe side, let it air dry for 15-20 minutes or use a hand fan like I occasionally do. One other thing I do with the cartridges after cleaning them and the slot is spread a little Deoxit on the pins for an extra conductive layer. It's not entirely necessary, but I do it for peace of mind.
It's the most brilliant stuff for cleaning retro machines. I've dismantled all my eight consoles at least once and cleaned everything. Obviously it doesn't fix faulty components,but often dirt and oxidation are the culprits anyway.
DrillbitNights - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 227
crwdns2942667:0crwdne2942667:0 84,354
