How to Use a Heat Gun to Soften Adhesive
crwdns2942287:0crwdne2942287:0Follow these instructions to use a heat gun to soften adhesive. Using a hair dryer is similar, but its procedure varies slightly.
A heat gun is a handheld device that emits a stream of hot air, usually at temperatures between 100 °C and 550 °C (200-1000 °F), with some hotter models heating up to 760 °C (1400 °F).
Before beginning, refer to the specific repair guide for detailed instructions such as the adhesive location and any surrounding sensitive components. Check your heat gun's user manual for any specific operating or safety procedures.
Place the device on a clean, heat resistant surface or mat.
Turn on the heat gun.
Position the tip of the heat gun 2–3 inches above the device.
Move the heat gun along the area where the adhesive is located.
Allow the heat gun to cool down before you store it.
For other general electronics skills guides, click here.
crwdns2935229:014crwdne2935229:0
Thanks. You answer the question of temperature quite well, but leave open the question of duration. How long does it take to soften the glue sufficiently to remove the screen?
That will depend on things like how big the screen is and how strong the adhesive is.
Chris -
Compré uno nuevo y cuando lo encendí en calor, se fundió a los 5 segundos, y seguí las instrucciones de mantenerlo lejos
