How to Solder Components onto the Beats Pill 1.0
  1. How to Solder Components onto the Beats Pill 1.0, How to Solder Components onto the Beats Pill 1.0: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Plug in the soldering iron and let it reach optimum temperature.
    • The soldering iron is very hot. Please do not touch the the tip of the iron when it is plugged in or until the iron cools.
    • Make sure it is plugged into a 150W outlet (common household wall outlet). Check the device for damages and impurities on the tip such as plastic or grease. Please make sure the iron is not in any contact with potentially flammable items and clean the tip if the soldering iron has been heavily used.
  2. How to Solder Components onto the Beats Pill 1.0: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check that the connection between the wire and the device has good contact. Prior to beginning the soldering process make sure the the conjoining connections between the wire and the device are properly wound together.
  3. How to Solder Components onto the Beats Pill 1.0: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply solder agent to iron until the tip of the iron is coated in the metallic agent. This agent needs to be heated to just under 400 Celsius. Use precaution not to drop hot soldering on you.
  4. How to Solder Components onto the Beats Pill 1.0: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Touch the soldering iron to the connection and evenly apply a layer of solder to connect and create a good a connection between the wire and the device.
    Yeah, you know that saying “Those who can’t do, teach”? I think it was originally more like “Those who can no longer do, teach.” The second one implies that the one teaching has the knowledge to pass on due to them once being able to do…whatever. But the first implies that you don’t need to even know how to do…whatever, you can still teach. That’s incorrect. If you don’t have the knowledge, don’t try teaching it. That’s how bad knowledge gets around and we end up with a generation of idiots. Just saying.
    Jeremy Cotter - crwdns2934203:0crwdne2934203:0
  5. How to Solder Components onto the Beats Pill 1.0: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally wait until the solder cools before re-assembly. It should cool within seconds of application.
Paul Haas
crwdns2935283:001/13/15crwdne2935283:0
778 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-2, Hickman Winter 2015 crwdns2935289:0USF Tampa, Team 3-2, Hickman Winter 2015crwdne2935289:0
USFT-HICKMAN-W15S3G2
As a developer with Google's platform to enhance the Google Assistant A.I. with better commands, your website recognized my online profile and asked if I would provide better pictures for just soldering process and I would be honored as I'm currently performing this repair now, stay tuned!
Jamie J. - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,547
