Plug in the soldering iron and let it reach optimum temperature.
Check that the connection between the wire and the device has good contact. Prior to beginning the soldering process make sure the the conjoining connections between the wire and the device are properly wound together.
Apply solder agent to iron until the tip of the iron is coated in the metallic agent. This agent needs to be heated to just under 400 Celsius. Use precaution not to drop hot soldering on you.
Touch the soldering iron to the connection and evenly apply a layer of solder to connect and create a good a connection between the wire and the device.
Finally wait until the solder cools before re-assembly. It should cool within seconds of application.
As a developer with Google's platform to enhance the Google Assistant A.I. with better commands, your website recognized my online profile and asked if I would provide better pictures for just soldering process and I would be honored as I'm currently performing this repair now, stay tuned!
