How to Restore a Torn Nike Flip-Flop
crwdns2942287:0crwdne2942287:0Nike Flip-Flops are a very common item in a person's wardrobe. Using these Nike Flip-Flops constantly causes wear and tear, which could be dangerous to the person wearing them. As the flip-flops tear they become unstable and can cause foot injuries like a sprained ankle. This guide will help protect you feet, by fixing the torn parts and making the Nike flip-flops more stable.
crwdns2944105:0crwdne2944105:0
Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
Clean off any additional residue with soap, water, and a towel or toothbrush.
Allow the flip-flop to air dry before moving on.
Gently apply the adhesive on the torn parts of the flip-flop.
Make sure the torn parts are completely covered. Overspill is okay.
Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
Once the adhesive is dry remove any extra adhesive that might have spilled over with the sandpaper.
Take the needle and thread and begin to sew a cross stitch from the strap to the torn part of the flip-flop.
Cover the stitched region with Plasti Dip.
Allow 4 hours to dry.
The Nike Flip-Flop(s) are now restored and can be worn again.
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
Oh darn I see it now.lol
