How to Replace the Thermal Paste Inside Your Framework Laptop 12
  1. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Power down your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Power down your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Power down your laptop: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Set your laptop down: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set your Framework Laptop face-down on a clean work surface.
  3. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Loosen the bottom screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Loosen the bottom screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
    • Your laptop comes with a spare set of screws in the frame above the battery. Be careful—the replacement screws aren't captive.
  4. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Flip your laptop over: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop over so it's face-up on your work surface.
  5. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Open your laptop: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Open your laptop: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the Input Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the Input Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the Input Cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • There are magnets holding the Input Cover down, so you'll feel some resistance. If it feels like a lot of force is required, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Loosen the battery screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the six captive T5 Torx screws securing the battery.
  8. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the orange battery tab with your fingers and lift straight up to disconnect the battery.
    • The battery connector can be tight, requiring some force. If it feels like part of the battery won't come up, check that the battery screws are fully loosened.
  9. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery from the laptop.
  10. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Loosen the heatsink screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to loosen the four captive Torx T5 screws securing the heatsink.
  11. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Loosen the heatsink: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Loosen the heatsink: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Loosen the heatsink: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the flat end of your Framework Screwdriver under the heatsink arm labeled "2".
    • Twist the Framework Screwdriver to lift the heatsink arm and loosen the heatsink.
    • You'll feel some resistance from the thermal compound holding the heatsink in place.
    • If the heatsink won't budge, make sure you've fully loosened the four screws securing the heatsink.
    • Repeat the procedure with the heatsink arm labeled "3".
  12. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the heatsink: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the heatsink: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the heatsink.
  13. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Disassembly complete: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  14. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the old thermal compound: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Remove the old thermal compound: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of your Framework Screwdriver to scrape off and remove the thermal compound residue from the processor.
    • Use a few drops of high concentration (>90%) isopropyl alcohol and a lint-free cloth to wipe away the remaining residue.
  15. How to Replace the Thermal Paste Inside Your Framework Laptop 12: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you're reusing the heatsink:
    • Use the flat end of your Framework Screwdriver to scrape and remove the thermal compound residue from the heatsink.
  16. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Apply new thermal paste: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a small bead of thermal paste to the small rectangle on the processor.
    • Apply a small line of thermal paste to the larger rectangle on the processor.
    • Thermal paste is non-conductive, so don't worry if it spills over the rectangles.
  17. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Install the heatsink: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Install the heatsink: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully align and lay the heatsink over the processor.
    • Use your Framework Screwdriver to gradually tighten the heatsink screws in the marked order until they're snug:
    • First screw
    • Second screw
    • Third screw
    • Fourth screw, then back to the first
    • This helps compress the thermal compound evenly under the heatsink and apply even pressure over the processor.
  18. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Install the battery: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the battery in its recess in the laptop.
  19. How to Replace the Thermal Paste Inside Your Framework Laptop 12: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to push the battery down near its connector to reconnect it.
  20. How to Replace the Thermal Paste Inside Your Framework Laptop 12: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Framework Screwdriver to tighten the six captive T5 Torx screws to secure the battery.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
  21. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Install the Input Cover: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Install the Input Cover: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Install the Input Cover: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  22. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Close and flip your laptop: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Close and flip your laptop: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  23. How to Replace the Thermal Paste Inside Your Framework Laptop 12, Tighten the bottom screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Thermal Paste Inside Your Framework Laptop 12, Tighten the bottom screws: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297,992 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:013,427crwdne2935297:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 115
