How to Replace the Screen Adhesive for Your Google Pixel 7 Pro
  1. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the frame: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    crwdns2942207:0crwdne2942207:0
    • Any residual adhesive or debris will prevent your screen from sealing properly.
    • Use the flat end of your spudger to scrape off as much adhesive as you can.
    • Use tweezers or your fingers to peel and remove any remaining adhesive.
    • Take care not to puncture the battery with your tweezers—a punctured battery may leak dangerous chemicals or cause a fire.
    • Clean the perimeter of the frame with a small amount of highly-concentrated isopropyl alcohol (over 90%) and a lint-free or microfiber cloth.
  2. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Clean the screen: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you're reusing your screen, clean it as you did for the frame.
  3. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Orient the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Orient the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before applying the new adhesive, lay it over the frame to find its proper orientation.
    • Use features such as the front-facing camera, upper loudspeaker, and corner notches to orient the adhesive.
  4. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the adhesive backing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pull tab on the top of the adhesive to remove the clear protective backing.
  5. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Apply the adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lay the adhesive onto the frame, starting with the bottom edge. Make small corrections as you go.
    • Use the bottom left notch, top right notch, and upper loudspeaker cutout to help align the adhesive.
  6. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to firmly press along the perimeter of the adhesive and adhere it to the frame.
  7. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Remove the liners: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the pull tab on the lower right of the frame and peel off the main liner.
    • There's a smaller liner under this one. Don't remove it yet.
  8. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Check for liners: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Check the front-facing camera hole and sensor cutout on the replacement screen and remove any remaining protective liners in it.
  9. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Continue reassembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Return to your phone's guide and continue reassembly.
    • Remember to reinstall the display cable bracket.
    • Finish this guide when your screen is installed and you're ready to seal the phone up.
  10. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the pull tab on the upper left of the frame and remove the liner covering the perimeter adhesive.
    • Make sure the adhesive doesn't peel up with the liner.
  11. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Install the screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Install the screen: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the screen over and lay it onto the frame.
    • Press along the perimeter of the screen to secure it.
  12. How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Replace the Screen Adhesive for Your Google Pixel 7 Pro, Strengthen the adhesive bond: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Screen Vise Clamps 6-Pack
    $15.99
    • To evenly compress your Pixel and strengthen the bond of the screen to the frame, you need to account for the camera bar.
    • If you have screen vise clamps, you can work around the camera bar. Secure the clamps to the perimeter of the device.
    • Apply tape to the perimeter of your rear glass to protect its finish.
    • Place coins or similarly thick objects along the edges of the rear glass. Make sure they're as thick or thicker than the camera bar.
    • Stack multiple books or other heavy objects on your phone. Leave them in place for thirty minutes or longer. Ideally, leave them stacked overnight.
crwdns2935229:030crwdne2935229:0
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
254,622 crwdns2915208:0crwdne2915208:0
crwdns2935297:0529crwdne2935297:0
Staff
crwdns2931471:0136crwdne2931471:0
crwdns2935297:017,430crwdne2935297:0
crwdns2917034:0crwdne2917034:0
crwdns2936751:024crwdne2936751:0 18
crwdns2936753:07crwdne2936753:0 123
crwdns2936753:030crwdne2936753:0 604
crwdns2942667:0crwdne2942667:0 11,508
