Use this guide to remove and replace the rear panel in your Whirlpool WRS315SDHW Refrigerator. Removing the rear panel gives you access to the evaporator fan, coils, and other components.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Turn off your main water supply
Unplug your device
Use a 1/4 inch socket wrench, or a flathead screwdriver, to remove the seven 16.2 mm-long screws securing the rear panel.
Use a 1/4 inch socket wrench to loosen the screw securing the water hose enough for the rear panel to freely move.
Pull the rear panel off the chassis to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
