Use this guide to replace the rear panel in your Whirlpool Refrigerator. Removing the rear panel gives you access to the evaporator fan, coils, and other components.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Turn off your main water supply
Unplug your device
Remove the screw(s) securing the rear panel.
Loosen the screw securing the water hose enough for the rear panel to freely move.
Pull the rear panel off the chassis to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
crwdns2917034:0crwdne2917034:0
How do you remove rear panel on the inside of whirpool french door refrigerator
