How to Remove a Wheel Lock Without a Key
  1. How to Remove a Wheel Lock Without a Key, Wheel Lock: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove a Wheel Lock Without a Key, Wheel Lock: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove a Wheel Lock Without a Key, Wheel Lock: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clean the wheel lock to make sure there is no debris on the surface of the lock.
  2. How to Remove a Wheel Lock Without a Key: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove a Wheel Lock Without a Key: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find a 12-point socket that barely fits over the wheel lock.
    • The socket should not be loose enough to revolve around the wheel lock.
  3. How to Remove a Wheel Lock Without a Key: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove a Wheel Lock Without a Key: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the socket in place.
    • Use a hammer to hit the socket until it is tight around the lock.
    • Gloves are recommended to prevent hand injury.
  4. How to Remove a Wheel Lock Without a Key: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove a Wheel Lock Without a Key: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the socket using the socket wrench.
    • Turn left to loosen. If you cannot turn the wrench easily, get a longer wrench for more torque.
  5. How to Remove a Wheel Lock Without a Key: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove a Wheel Lock Without a Key: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove a Wheel Lock Without a Key: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Now that the wheel lock is off, it will be stuck to the socket.
    • Insert the screwdriver into the square-opening on top of the socket.
    • Hit the top of the screwdriver with the hammer a few times until the lock falls out of the socket.
    A few points about this step:
    * It is very hard to do unless you have a bench vise to hold the socket. The wheel lock would not come out of it's socket until I put both into a vise
    * Using heat on the socket is not a bad idea.
    * Don't use a screwdriver, use a solid piece of metal instead. Most screwdrivers will just deform and or the blade will just be driven into the plastic handle.
    Dennis Favro - crwdns2934203:0crwdne2934203:0
  6. How to Remove a Wheel Lock Without a Key: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove a Wheel Lock Without a Key: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove a Wheel Lock Without a Key: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab a regular wheel nut.
    • Screw on the wheel nut by hand.
    • Use the tire iron to tighten the wheel nut.
    Merci, j'ai suivi les instructions et ça a marché! Moins de 5 minutes. Pour moins de 4 euros d'achat d'une douille 22 pans de 19mm de diamètre, moins cher qu'une extraction d'écrou chez un professionnel
    Damien - crwdns2934203:0crwdne2934203:0
Hesham Annamer
crwdns2935283:009/17/20crwdne2935283:0
244 crwdns2915208:0crwdne2915208:0
University of Memphis, Team S1-G1, Bishop Fall 2020 crwdns2935289:0University of Memphis, Team S1-G1, Bishop Fall 2020crwdne2935289:0
UM-BISHOP-F20S1G1
Hi, I have a 05 dodge dakota that has 4- 8 spline thin wall deep socket lug nuts on them. I have went to every tire/mechanic shop and tool store. I really need to get these off so I can change my breaks!!
If there's anything or any advice you can give on how to get these suckers off, I would greatly appreciate it 🙏🏽
As my husband has been trying for over a week now!!
SK Seid - crwdns2934203:0crwdne2934203:0
Those are really tricky to get out, i remember welding on a 17mm nut properly and then using impact to get that out son years ago, last option in usually drilling out the whole stud and socket, both options are really frustrating especially if you have expensive rims. If u can hammer on a socket a impact gun will get that out.
Nirap Singh -
I was skeptical, but this did in fact work on my 2005 Honda CRV spare tire wheel lock. I used a 3/4 inch 12 point socket. Hammered it on and it came off easily. Can't get the wheel lock nut out of the socket, but well worth losing a socket to get off the nut.
Atomic Night Light - crwdns2934203:0crwdne2934203:0
I recently had the same issue. I thought I lost the key lock for my BMW. I contacted a vendor and was told they could replace it, if I sent them a picture of it. My son was taking the picture when he saw it in the loug bolt. I believe its been there for a few months .
Bill D - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 99
crwdns2936753:07crwdne2936753:0 561
crwdns2936753:030crwdne2936753:0 2,110
crwdns2942667:0crwdne2942667:0 142,320
