How to Remove a Broken and Embedded Screw
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
  2. How to Remove a Broken and Embedded Screw: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
  3. How to Remove a Broken and Embedded Screw: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
  4. How to Remove a Broken and Embedded Screw: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
  5. How to Remove a Broken and Embedded Screw: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
  6. How to Remove a Broken and Embedded Screw: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
  7. How to Remove a Broken and Embedded Screw: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Remove a Broken and Embedded Screw: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw the new screw inside the freed hole.
Ismael Diaz
crwdns2935283:010/06/21crwdne2935283:0
217 crwdns2915208:0crwdne2915208:0
University of Puerto Rico Mayagüez, Team 2-17, Cools Stephens Fall 2021 crwdns2935289:0University of Puerto Rico Mayagüez, Team 2-17, Cools Stephens Fall 2021crwdne2935289:0
UPRM-COOLS STEPHENS-F21S2G17
It all sounds great, but... It didn't work. I have a Porter-Cable older router. The first screw in the base came out without a problem, and the other 2 screws wouldn't budge. I tried various penetrating oils and nothing. I drilled one of the screws and tried an extractor...nothing. I cut off the screw and drilled clean through, then tried the extractor again...nothing. So, what's left of the screw is drilled out, won't budge with a hole, and is laughing at me.
Although I haven't tried it yet, I was going to cut of the base, leaving the screw intact, getting some vise grips and try to twist it out.
Any other ideas??
frustrated home improvement - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 126
crwdns2936753:030crwdne2936753:0 557
crwdns2942667:0crwdne2942667:0 13,824
