These instructions provide a simple technique for reattaching a broken piece of wood to any type of furniture. We demonstrate this technique on a nightstand, but it can be used on any wooden surface that needs to be fixed. No carpentry skill is required to complete this repair.
Dust the surface of the fragment and the damaged area of the furniture.
Any household cleaner will work; we recommend a damp rag.
Check that the fragment fits well into the break in the furniture.
Apply glue to both the fragment and the furniture.
Check that the glue is spread evenly throughout both pieces.
Insert the wood fragment into the glued spot on the furniture.
Wipe away any excess glue using a damp rag.
Clamp the two pieces together.
You can use any type of clamp that you have on hand. If you don't have a clamp, any type of clip would work.
Wait 30 minutes for the glue to dry before removing the clamp.
Continue using furniture as you had before!
Thank you for the post. It will help me with the leg if a cigar table. However, a piece of wood broke off the front of my mom’s cedar chest and I won’t be able to use a clamp. What do you recommend?
The clean and modern design of our products allows you to use the items for years. we are starting to sale small products and want to get your feedback for these products. We are not the World best online store but we want to be and this is only possible with your response and recommendation.
Very easy to follow instructions. I've found the most difficult part of any fence build is getting the posts lined up properly and getting them plumb. Even with a line, it can be tough . https://www.whitewooden.com/
This blog is very useful for me to know about how to attach a broken wood pieces in a furniture and will be very useful for many '''furniture showrooms in Chennai.''' Thanks keep updating.
siva Kumar - crwdns2934203:0crwdne2934203:0
