How to Realign a Sliding Closet Door
  1. How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door, How to Realign a Sliding Closet Door: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Investigate the cleanliness of the tracks.
    • If the tracks are dirty, scrub them with toothbrush to clean out the dust.
    • You can use a rag or a hand vacuum to remove the loosened dust.
    How do you clean tracks with vacuum or tooth brush
    Kevin Tremaine - crwdns2934203:0crwdne2934203:0
    I like the bolding of "clean out dust"
  2. How to Realign a Sliding Closet Door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Investigate whether the sliding door is along the top tracks.
    • If the door is completely unhooked from the top tracks:
    • Try to lift up on the door.
    • Slightly push the door in toward the closet.
    • Hook in the top rollers back onto the upper tracks.
    Add caution to lifting - closet door could be potentially hazardous
    What if there are no bottom track . ? Every time I put one side on the track the other side comes off..
    wendrarook - crwdns2934203:0crwdne2934203:0
    Do you know what is the name or model of the door and wheel mechanism pictured here? I have the same kind and I am having trouble finding a replacement screw for it.
    newacct - crwdns2934203:0crwdne2934203:0
  3. How to Realign a Sliding Closet Door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the bottom rollers do not align, follow these steps:
    • CAUTION: The doors may be heavy. Ask somebody for assistance.
    • Do not force anything.
    • Gently try to lift up on the door and guide its bottom rollers into the bottom tracks.
    • If the door still needs to be realigned, continue to Step 4.
    • If the door is successfully realigned with the bottom tracks, continue to Step 6.
  4. How to Realign a Sliding Closet Door: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top rollers up, then above and onto the top tracks.
    • This is what gives the door enough space to fit back into the bottom tracks.
    • If this doesn't work, see Step 5.
  5. How to Realign a Sliding Closet Door: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Another sliding door behind may be creating a space constraint.
    • Grab the sliding door that is behind it.
    • Lift it up so that the rollers at the bottom disconnect with the track.
    • Keep the top rollers connected.
    • Put down the door so that the bottom rollers are behind the track, closer to the closet.
  6. How to Realign a Sliding Closet Door: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the door in front.
    • Attach it to both the top and bottom tracks.
    • Grab the door behind and do the same.
  7. How to Realign a Sliding Closet Door: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Realign a Sliding Closet Door: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The doors should be located properly on their tracks.
    • Try to slide the doors along the tracks.
    • If they don't slide well, you may need to lubricate the tracks:
    • Grab a lubricant: olive oil, fish oil, mineral oil, or petroleum jelly.
    • Apply a small amount of the lubricant to the edge of the rag.
    • Fit the edge of the rag into the tracks.
    • Spread the rag throughout the tracks to spread the lubricant.
    • Slide the closet door along the tracks to spread the lubricant further.
    Lubrication isn't the same as misaligned tracks, perhaps your fix should be how to fix a difficult opening closet door
Thank you for considering this guide. To maintain properly working sliding closet doors, periodically clean and lubricate the tracks as described in this guide.
crwdns2935229:013crwdne2935229:0
Annamarie Roger
crwdns2935283:004/09/15crwdne2935283:0
476 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 28-5, Green Spring 2015 crwdns2935289:0Cal Poly, Team 28-5, Green Spring 2015crwdne2935289:0
CPSU-GREEN-S15S28G5
crwdns2935297:011crwdne2935297:0
Bonjour :)
Je suis très contente de vos explications accompagnées de photos !
Elles vont m'être très utiles pour, enfin, remettre en état mon placard coulissant ;)
Merci beaucoup ! Vous êtes géniale !
Claire.
Defontaine - crwdns2934203:0crwdne2934203:0
Hi, so this was sorta useful for me but I still have another question. My door slides along the floor and doesn't have a bottom track. Any tips as to how I'd go about fixing it? Thanks
Flying Dolphin 101 - crwdns2934203:0crwdne2934203:0
Very helpful, helped me fixed a cabinet door. Thanks a lot !
Mem's - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 36
crwdns2936753:07crwdne2936753:0 299
crwdns2936753:030crwdne2936753:0 1,191
crwdns2942667:0crwdne2942667:0 284,142
