How to Open Your Logitech MX Anywhere 2S
  1. How to Open Your Logitech MX Anywhere 2S, Heat the mouse feet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. How to Open Your Logitech MX Anywhere 2S, Separate the mouse foot adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Separate the mouse foot adhesive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Separate the mouse foot adhesive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick between a mouse foot and the lower case.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • If the pick feels stuck, apply more heat before continuing.
  3. How to Open Your Logitech MX Anywhere 2S, Remove the mouse foot: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Remove the mouse foot: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel up and remove the mouse foot.
  4. How to Open Your Logitech MX Anywhere 2S, Remove the remaining feet: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Remove the remaining feet: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Remove the remaining feet: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous two steps to remove the remaining mouse feet.
  5. How to Open Your Logitech MX Anywhere 2S, Reassembly information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Reassembly information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Reassembly information: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  6. How to Open Your Logitech MX Anywhere 2S, Unfasten the lower case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws securing the lower case to the upper shell.
  7. How to Open Your Logitech MX Anywhere 2S, Remove the upper shell: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Remove the upper shell: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Open Your Logitech MX Anywhere 2S, Remove the upper shell: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip your mouse over and grab the upper shell.
    • Lift the front edge of the upper shell upwards.
    • Lift the upper shell straight off of the mouse.
    • During reassembly, lay the front edge of the upper shell into place, then press down to engage the rear clip.
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
86,469 crwdns2915208:0crwdne2915208:0
crwdns2935297:0454crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:09crwdne2931471:0
crwdns2935297:013,534crwdne2935297:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 90
crwdns2936753:030crwdne2936753:0 397
crwdns2942667:0crwdne2942667:0 8,822
