How to Force Restart an iPhone 5s
  1. How to Force Restart an iPhone 5s, How to Force Restart an iPhone 5s: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Force Restart an iPhone 5s, How to Force Restart an iPhone 5s: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and hold the Home button.
    • While holding the Home button, press and hold the Sleep/Wake button.
  2. How to Force Restart an iPhone 5s: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Force Restart an iPhone 5s: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue holding both buttons for about 10 seconds, until the Apple logo appears.
    It didn’t work it still shows that battery is dead
    BACHIR KAZMA - crwdns2934203:0crwdne2934203:0
    How to force restart it when my home button is broken?
    My iPhone 5s is showing the “press home to upgrade” and my home button is broken.
    It appears after my phone battery was empty and when I charged it the “press home to upgrade” is showing.
    Kindly help me to fix it too.
    Thank you!
    Mj Congayo - crwdns2934203:0crwdne2934203:0
    magnifica guia para hacer los cambios y reparaciones. muchas gracias.
    Faustino Avelino - crwdns2934203:0crwdne2934203:0
crwdns2935229:0328crwdne2935229:0
Dante Mazzanti
crwdns2935283:007/13/15crwdne2935283:0
36,418 crwdns2915208:0crwdne2915208:0
crwdns2935297:026crwdne2935297:0
crwdns2947412:044crwdne2947412:0
What to do if your iPhone won't turn on
cashaysmith - crwdns2934203:0crwdne2934203:0
I dropped my iPhone and the screen went dark. It still rings, take messages but the screen will not light up
Evelyn Smith - crwdns2934203:0crwdne2934203:0
try and replace the screen
james huynh -
It’s definitely faulty you would need to change the screen
I currently have the same issue
Ajibola Joel Oyelakin -
my self NIhal i ant small help can u plz help out from this problem my iphone 5s when i try too on its not going on but when i plug the charging cable too the charging port it will goes in iphone recovery mode and i was trying to restore or update the mobile with itunes failed to update like error 4013 what is the solution help me
King Khan - crwdns2934203:0crwdne2934203:0
this is my mail id Alhumdulilah67@gmail.com
The energy went out while updating so im stuck at white apple screen with progress bar not moving. Cant do this because home button is broken. What to do?
Alejandro Cordova - crwdns2934203:0crwdne2934203:0
Sounds like you'll have to replace the home button just so that you can boo the iPhone into recovery mode.
markallenhowell - crwdns2934203:0crwdne2934203:0
does it matter if the buttons are pressed in the opposite order?
Robert Sterbal - crwdns2934203:0crwdne2934203:0
My phone won't turn on and I did just like the instruction said and even tried hard resetting it but nothing happened. I don't know what to do now. I even opened the iPhone 5s over 3 times to check if something went wrong bang it's all good and connected but for some reason it won't turn on even after hard reset. Someone help me please.
dumebi Obiemeke - crwdns2934203:0crwdne2934203:0
My iPhone 5s will not ring for incoming calls. It sends caller to voice mail.  Any  suggestions would be appreciated…
Thanks much
Wayman Nelson - crwdns2934203:0crwdne2934203:0
If the speaker works fine when play music, I think your issue is caused the logic board or your carrier.
Takehiro -
My iphone 5s is getting activated. I bought from South Africa and restored it once in India. Now it is not activating. Please suggest me something.
akshay khedkar - crwdns2934203:0crwdne2934203:0
If your iPhone is SIM free, you can activate with India SIM.
If your iPhone is not SIM free, you can use iPhone via Wi-Fi without activate when SIM is removed.
Takehiro -
Best instructions I’ve ever seen. Easy to follow and includes info on what to check if there’s a problem. Unfortunately I still have the white lines and touch screen doesn’t work. I must have damaged something. Won’t be buying another apple. They refused to look at it because I changed the battery myself.
Bryan Thompson - crwdns2934203:0crwdne2934203:0
Now that I have read guide no way I am doing this myself. My 5s needs charging constantly. If Appleis doing this they should replace all batteries free. Any suggestions to make battery run for a longer time or must I get someone to install new one?
Rochelle Barstow - crwdns2934203:0crwdne2934203:0
iPhone 5s/ can't be activated or an alert says the activation server is unavailable
amjad - crwdns2934203:0crwdne2934203:0
I have the same problem , my iphone went from a slightly red color to black, i can still hear my phone vibrating when someone tries to call me and when i receive a message but my screen is still dark i tried your method but it still isn’t responding
Martha Edwards - crwdns2934203:0crwdne2934203:0
if i had ONLY followed this perfect site, I would not have had to do replacement again!!!
Thank you
Rick Hieber - crwdns2934203:0crwdne2934203:0
If the home button is not working then
Syed Ilyaz - crwdns2934203:0crwdne2934203:0
I used www.HardReset.info to perform a hard reset in iPhone X, and everything went well. I just recommend this site.
mateuszsyzdek - crwdns2934203:0crwdne2934203:0
Hi all,
i have a problem with my iphone 5s yesyarday. when i put in charge its turn on but dont charge.
somebody can help me… its already clean.
carlos - crwdns2934203:0crwdne2934203:0
Pls help how to remove apple id or icoud account plss reply
maico sitao - crwdns2934203:0crwdne2934203:0
I don’t understand why my old iphone5s won’t turn on. When I insert my charger, it shows the battery with it red. I use this method bu it won’t work. Someone help me!
Anastasia Compton - crwdns2934203:0crwdne2934203:0
You may have to replace the charge port. The same thing happened to mine last year. I thought the batter was bad and I replaced it. After I got it home, could not get it to charge. The problem was the charge port was loose and needed replaced. Had it done at a cell phone repair shop for $35.00 and have not had any issues since.
Hope Bobo -
2020 here .anyone?
How can i fix my iphone 5s if i accidentally throw in a bin but full of water.
ROLAN LUNGUB - crwdns2934203:0crwdne2934203:0
My phone will not react to any screen touch at all so I cannot slide the “power off”, cannot make calls, cannot use it AT ALL!
Hope Bobo - crwdns2934203:0crwdne2934203:0
My iphone disable unlock . Plss help
kiemahnurul - crwdns2934203:0crwdne2934203:0
LOL this is the Ice Cube Recipe of ifixit.com.
nickjg - crwdns2934203:0crwdne2934203:0
Thank you for your help, so easy to do. and love the fact we can keep our products working rather than throw throw them away. WELL DONE Ifixit.com Keep up the good work
billythefish66 - crwdns2934203:0crwdne2934203:0
It does not work. My Iphone 5s does not turn on anyway.
Anita Ros - crwdns2934203:0crwdne2934203:0
It did not work for me. My Iphone 5s is still dead. What can I do?
Thank You so much. could not get touch or password to open. forced quit wouldn't slide. Siri would not help. So simple to fix once you know what to do.
Derek Hogeweide - crwdns2934203:0crwdne2934203:0
Evelyn Smith, you dropped it, how could possibly work from a force restart?
The repair - crwdns2934203:0crwdne2934203:0
Thank you for providing the path to fixing!!!
Kin - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 268
crwdns2942667:0crwdne2942667:0 225,477
