How to Fix a Sticking Deadbolt
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Sticking Deadbolt: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Sticking Deadbolt: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Sticking Deadbolt: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Sticking Deadbolt: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix a Sticking Deadbolt: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix a Sticking Deadbolt: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
After following this fast fix guide, the sticking deadbolt should be fixed.
Elizabeth Nesler
crwdns2935283:002/23/16crwdne2935283:0
220 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 22-5, Rauch Spring 2016 crwdns2935289:0Texas Tech, Team 22-5, Rauch Spring 2016crwdne2935289:0
TTU-RAUCH-S16S22G5
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - crwdns2934203:0crwdne2934203:0
Thank you! GumOut worked well. (I was amused to realize I already had it in my shed for cleaning my lawn mowers carburetor.) In my situation the deadbolt wouldn't fully retract with the key any more, but I could push it the rest of the way with my finger. After removing the latch in step 3, I could turn the latch with a flat head screwdriver and find the place where it "sticks." After cleaning the latch out with a few sprays of GumOut and exercising it with a flat head screwdriver, the latch was working smoothly again. Thank you for the helpful guide!
Russ Williston - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 40,274
