Have you ever opened a door too hard and it hit the wall causing a small hole in the wall? This is a problem that so many people have, especially with children in the home. Most modern homes have walls made of a material called drywall. A hole in drywall is very easy to patch. It requires no prior skill or experience. This fix requires inexpensive tools and materials that you may find at a local hardware store or you may even already have some of these items at home. This is a guide on how to patch a small hole in the wall for beginners. This guide will include a complete step by step guide along with all tools and materials that are needed to complete this task.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
Use a damp sponge to apply moisture to make the mesh stick to the wall, covering the entire hole.
Use a drywall knife to apply the drywall compound over the mesh. Make sure to spread a generous amount over the entire mesh.
Let the compound dry for about 30 minutes.
Once compound is dry, use sandpaper to smooth out the entire surface of the dried compound.
Paint over the surface with a paint brush.
Oi! como faço reboca que a parede está pintada branca?
