How to Fix a Broken Necklace
  1. How to Fix a Broken Necklace, How to Fix a Broken Necklace: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay your chain necklace on a flat surface.
    • This will keep the chain from tangling.
  2. How to Fix a Broken Necklace: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the broken link.
    • Place the pliers on the right of the small opening on the chain.
    • Keep your hand a few centimeters lower than the opening of the chain to avoid accidental injuries.
    "Identify the smaller and wider hole on the soda tab. Make a small cut along the edge towards the center of the hole."
    Specify which hole you're cutting.
    Andrew Yoder - crwdns2934203:0crwdne2934203:0
  3. How to Fix a Broken Necklace: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull one side of the link down slightly to make the gap in the chain larger using the pliers.
    • This opens up the chain allowing you to work with it easily.
  4. How to Fix a Broken Necklace: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Broken Necklace: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat step three on the opposite side of the chain.
  5. How to Fix a Broken Necklace: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Broken Necklace: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take both ends of the chain and hook them together.
  6. How to Fix a Broken Necklace: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix a Broken Necklace: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Close the chain by using the pliers to push the link to its original position.
  7. How to Fix a Broken Necklace: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat step six to close the other chain link.
  8. How to Fix a Broken Necklace: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Your jewelry is ready to be worn!
This creative guide can be used for all accessories whether big or small, wide or thin. Now you can restore old, broken, accessories that still have a special place in your heart.
Salonee
crwdns2935283:004/09/15crwdne2935283:0
263 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 28-4, Green Spring 2015 crwdns2935289:0Cal Poly, Team 28-4, Green Spring 2015crwdne2935289:0
CPSU-GREEN-S15S28G4
crwdns2931471:06crwdne2931471:0
crwdns2935297:017crwdne2935297:0
Always great to be able to repair and reuse broken jewelry. A tip on how to add a bright, metal jump ring or chain to an older, more tarnished necklace is to use the flame of a wooden match to burn the newer metal. It will give it an antique look. Try doing it on just one bit of metal to see how it reacts. And, always hold the metal with your pliers, not your hands, when you're burning it. Allow it to cool. Wipe off excess tarnish with a tissue. Note: this needs a wooden match, not a lighter.
Also, to polish sterling chains, you can use a q-tip with fireplace ashes. They work great!
janiceparsons - crwdns2934203:0crwdne2934203:0
Fixed a broken chain bracelet with your method!
Thanks a bunch :)
Mihai Patrascu - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,046
