How to Fix Xbox 360 Controller Joystick Drift
Luis Ramirez
crwdns2944107:0crwdnd2944107:0Luis Ramirezcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0N'w 19, 2024crwdne2944111:0
5 - 8 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
If your Xbox 360 controller is encountering joystick drift, use this four-step guide to repair your Xbox 360 controller. One of the most frustrating problems a gamer may have with their Xbox 360 controller is joystick drift. A joystick is used to interact when playing video games and can move in all directions. Joystick drift occurs when the controller's joystick moves on its own due to dust build-up. The build-up of dust can cause in-game character movements or camera angles to change without the player's input. The drift can significantly impact a player's gaming experience, making it difficult to control their character and perform actions accurately. Fortunately, it is very simple to fix joystick drift on an Xbox 360 controller and there is no need to purchase a new controller. This four-step guide will teach you the most effective solution for fixing joystick drift and getting your Xbox 360 controller back in working order.
crwdns2944105:0crwdne2944105:0
  1. How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Xbox 360 Controller Joystick Drift, How to Fix Stick Drift on Xbox 360 Controller: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove seven screws from the back of the controller using a T8 Torx screwdriver.
  2. How to Fix Xbox 360 Controller Joystick Drift: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Xbox 360 Controller Joystick Drift: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back to see the motherboard.
    • Do this with caution as it could easily be damaged if wires disconnect.
  3. How to Fix Xbox 360 Controller Joystick Drift: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Xbox 360 Controller Joystick Drift: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently dab a cotton swab with isopropyl or rubbing alcohol to the joystick in a circular motion.
    • Be careful when adding liquid; too much liquid can damage the controller.
  4. How to Fix Xbox 360 Controller Joystick Drift: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Xbox 360 Controller Joystick Drift: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a blow dryer to dry both the left and right joysticks.
    Can i use colonel or perfume that has alcohol in it?
    Bdalrhmn - crwdns2934203:0crwdne2934203:0
    Craig Timmerman (Bobby Fulton) - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Luis Ramirez
crwdns2935283:008/25/22crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
This is not a genuine Xbox 360 controller and you truly aren't doing anything at all. You haven't even removed the thumbsticks to service the internals of the sensor assembly lol.
Alexander Dimitrov - crwdns2934203:0crwdne2934203:0
Hi, I did this with a genuine controller and it completely worked for me. I just wiped the metal frames and went round the inside-joystick that I could, with the Q-tip.
ShadowNinja5764 - crwdns2934203:0crwdne2934203:0
is replacing a joystick on a Xbox 360 wireless controller the same as replacing a joystick on a PowerA wired controller
batman2345 - crwdns2934203:0crwdne2934203:0
Not sure, but i do know you need to be careful. The circuit board in the Xbox controller is very easy to damage. The pads can lift easily if not careful when desoldering. Add solder before you try to desolder.
Burned -
I believe this is a fix only for if you get premature stick drift. Stick drift from prolonged/intense use requires replacement of parts.
Wes Plants - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 42
crwdns2936753:07crwdne2936753:0 240
crwdns2936753:030crwdne2936753:0 915
crwdns2942667:0crwdne2942667:0 32,314
