How to Fix Roccat Kova Double Clicking
  1. How to Fix Roccat Kova Double Clicking, How to Fix Roccat Kova Double Clicking: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking, How to Fix Roccat Kova Double Clicking: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the Roccat Kova over, with the bottom facing up.
  2. How to Fix Roccat Kova Double Clicking: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the four plastic mouse skates.
    • If you plan on reusing the mouse skates, take care not to stretch or tear them.
  3. How to Fix Roccat Kova Double Clicking: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew four screws using a Phillips screwdriver.
  4. How to Fix Roccat Kova Double Clicking: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slightly peel back the front edge of the plastic label, nearest to the wire coming out of the front of the mouse, until you see two screw holes.
    • Use a Phillips #00 screwdriver to remove the two screws.
    • Now you have detached all screws and should have a total of 4 long screws and two small screws
  5. How to Fix Roccat Kova Double Clicking: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently tilt the top case, from the front to the back, until you see white wires that connects the top case of the mouse to the bottom housing.
    • Do not pull the two halves apart quickly or entirely to avoid damaging the connections and/or motherboard.
    • Set the top of the mouse on your worksurface, with care not to strain the connections.
  6. How to Fix Roccat Kova Double Clicking: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To detach the wires from the bottom part of the mouse, grab the white plastic connector and pull it directly up and out of its port.
    • Do not pull from the wires directly as this could cause damage to the connections.
  7. How to Fix Roccat Kova Double Clicking: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the four microswitches boxes at the front edge of the mouse.
    • Each have a little white dash (clicking dash) in the middle.
    • Focus on the middle two front clicking boxes, and determine the faulty clicker.
  8. How to Fix Roccat Kova Double Clicking: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate and start taking off the normally functioning clicker's microswitch first.
    • Unclip the two edges of the box, using a thin flat head (1.0 mm). Gently push the flat head in the crack from the sides of the black box.
    • The clips of the black box are fragile. Do not over force the clips to bend.
  9. How to Fix Roccat Kova Double Clicking: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When the box has been popped off there will be two pieces: The main black box and a small white piece, make sure to keep all pieces in a safe area to avoid losing them.
    • Gently remove the box while tilting the mouse (45-90 degrees) to avoid losing the small white piece of plastic.
  10. How to Fix Roccat Kova Double Clicking: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the contact plate underneath the box.
    • It is a small gold H shaped piece of metal.
    • Note that this is the good and functioning plate.
  11. How to Fix Roccat Kova Double Clicking: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a flat head (1.0 mm) to carefully move it to the sides back and forth to take it out of place.
    • The plate is very thin and fragile. Do not over stress the plate, and try not to scratch it.
  12. How to Fix Roccat Kova Double Clicking: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous three steps for the left box.
    • Note that the left box it the malfunctioning clicker box.
  13. How to Fix Roccat Kova Double Clicking: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the deformed contact plate.
    • Insert a thin flat headed (1.0 mm) screwdriver in the arched metal area, and give it a little push as if you are trying to open that arched door.
    • Gently, push the arched area to an angle of 45-80 degrees to try to reinstall its integrity of functioning.
    • Do not over stress the plate, and do not go passed 90 degrees.
  14. How to Fix Roccat Kova Double Clicking: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully reinstall the metal plate in place. Make sure the arch is snug in place by pushing on it from the top with the flat head, gently and slowly until it clicks in place.
    • You will be swapping the left metal plate(malfunctioning) to the right, as it would not be overused allowing it to live longer. The one that was bent in the previous step should be placed into the right clicker.
  15. How to Fix Roccat Kova Double Clicking: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the white plastic piece in the hole in the black cover box by slowly feeding it in.
  16. How to Fix Roccat Kova Double Clicking: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the bottom half of the mouse to 45-90 degrees to avoid the spill of the white piece.
    • Position the cover so that its aligned with its initial position.
    • Push the cover into the mouse until you feel it clicking in place, and double check the clips are in place.
  17. How to Fix Roccat Kova Double Clicking: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Similar to Step 15, repeat the process for the other cover.
    • Note that you are placing the functioning plate in the left clicker as it would be overused. Hence, it will live longer.
  18. How to Fix Roccat Kova Double Clicking: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently position the top half of the mouse over the bottom.
    • Align the plastic base to the adapter with the white wires.
    • Connect the plastic base into the adapter.
    • Connect the top half and bottom half of the mouse.
  19. How to Fix Roccat Kova Double Clicking: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screw back the four long screws to each corner by rotating each screw clockwise direction (Righty tidy) until it is tight enough.
    • Do not over tighten the screws as it could damage the plastic threads.
  20. How to Fix Roccat Kova Double Clicking: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw back the two small screws under the front potion of the sticker by turning them clock wise direction.
  21. How to Fix Roccat Kova Double Clicking: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Fix Roccat Kova Double Clicking: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check if the mouse is working correctly.
And now you have a fixed mouse that can last for long time. Please, let us know if you have any questions and if there are any suggestions and/or feedback.
Abanob Yohanna
crwdns2935283:004/16/24crwdne2935283:0
367 crwdns2915208:0crwdne2915208:0
UC Davis, Team 2-1, Morris Spring 2024 crwdns2935289:0UC Davis, Team 2-1, Morris Spring 2024crwdne2935289:0
UCD-MORRIS-S24S2G1
Excellent, thank you very much! This helped me open the mouse. Didn't realize there are two more screws under the sticker.
However, I replaced the switches. There are ones that are 50M rated. They should last much longer that the 5M ones the mouse came with.
Highcarb Schwabe - crwdns2934203:0crwdne2934203:0
Looking to do the same to my Kova, may I ask where you acquired the 50M rated switches from?
GamerGuy - crwdns2934203:0crwdne2934203:0
The six screws under the mouse supriesed me. Couldn't do the bend correcly so I soldered just a new switch, works perfectly. Non then less, thanks ifixit for the guide. It's a quite rare mouse and it's good to see that for this type of devices there is a repair guide.
HiddenBear - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 1,247
