How to Fix Paint Chips or Large Scratches on a Car
  1. How to Fix Paint Chips or Large Scratches on a Car, How to Fix Paint Chips or Large Scratches on a Car: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wipe down the area of the paint chip or scratch with a damp papertowel.
  2. How to Fix Paint Chips or Large Scratches on a Car: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place tape around anything you do not want to get paint on.
    • e.g. windows, taillights/headlights, metal decals, license plates, etc.
  3. How to Fix Paint Chips or Large Scratches on a Car: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Sand down the paint chip or scratch, including the immediate surrounding area.
    • Start with a coarse grain.
    • Then move to a fine grain to remove any sharp edges.
    • Don't sand too far out around the area. The goal of using sandpaper is to reduce any edges to prevent rusting underneath the paint, and to create a surface that the primer will stick to.
  4. How to Fix Paint Chips or Large Scratches on a Car: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wipe down the area with a dry papertowel to remove debris.
  5. How to Fix Paint Chips or Large Scratches on a Car: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spray the primer all over the area that was sanded. Use small strokes and spray the primer around the area.
    • Wait 10 minutes or until it feels dry when touched.
    • Add another layer or two if you can still see the edge of the paint chip or scratch.
    • The goal is to fill in the scratch or chip with primer to prevent rust.
    • Let it dry for 15-20 minutes before moving to the next step.
  6. How to Fix Paint Chips or Large Scratches on a Car: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spray on a coat of colored paint. Use small strokes and spray the paint around the area.
    • Spraying at least 6 inches (no more than 10 inches) away from the surface will prevent paint from dripping.
    • Paint drips can be removed by gently dabbing them with a dry paper towel.
    • Allow to dry.
    • Drying time takes at least 10 minutes per coat of paint.
    • Continue adding coats and drying in between until primer cannot be seen through the paint.
  7. How to Fix Paint Chips or Large Scratches on a Car: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spray on the clear protective coat. Use small strokes and spray the clear coat around the area.
    • Allow to dry for 10 minutes or until the area feels dry when touched.
    • Add at least 3 more coats, allowing each coat to dry in between.
    • The clear coat helps prevent rust and adds a refective texture that helps the paint job blend in.
    • Remove masking tape from the car when finished.
    • If you accidentally got paint on your windows, it will come off if you scratch it with a flat razor.
Karly Ekren
crwdns2935283:004/14/20crwdne2935283:0
256 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S25-G5, Crane Spring 2020 crwdns2935289:0Eastern Washington University, Team S25-G5, Crane Spring 2020crwdne2935289:0
EWU-CRANE-S20S25G5
نحياتي لكل مجتهد ومساهم هنا
Abdullah Shaweil - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 154
crwdns2942667:0crwdne2942667:0 12,959
