Use this guide to put a Steam Deck into battery storage mode from within its BIOS.
Before opening up a Steam Deck to perform internal repairs, Valve recommends enabling battery storage mode for increased safety and to minimize any risk of damage to the device.
If you're enabling battery storage mode for long term device storage instead of repairs, discharge (or charge) your battery to 50-60% before enabling storage mode.
When in storage mode, your Steam Deck won't respond to power button presses. To exit storage mode, plug your Steam Deck into the charger.
Power down your Steam Deck.
Once off, hold down the volume up (+) button and press the power button.
Release both buttons.
Navigate to Setup Utility.
Navigate to the Power menu.
Select Battery storage mode.
Select Yes to confirm.
schlechte Übersetzung
"Battery Storage Mode" würde ich eher mit "Batterie deaktiveren", "Akku-Aufbewahrung" oder "Batterieschutzmodus" übersetzen. Ich würde den BIOS-Bereich (korrekterweise UEFI-Bereich) unübersetzt lassen, da das Menu ohnehin nicht auf Deutsch vorliegt.Perfect work
Worked like a charm! Thanks a bunch!
This worked for me to fix unresponsive touch screen. Thanks!
I did aplied thermal paste and when doing that i disconected the battery however all im getting is a white flashing light on the steam deck.
I did this and upgraded my SSD. Put it all back together and plug the charger in.it worked. But now it want turn on until I plug in the charger Everytime.
Go back to the BIOS and disable the battery storage option
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
crwdns2935229:0101crwdne2935229:0
crwdns2947412:017crwdne2947412:0
I thought that this mode is also for when you not going to use your Steam Deck for more than a week. And if so, what is the percentage of battery you should leave the Steam Deck with before putting it in storage.
The help page valve provides via the device indicates not to engage the mode above 80% state of charge.
From my personal experience with other devices and the state of charge the device ships at, I'd recommend something around 50% to 60% as a desirable storage point for best battery life during long-term storage
You discharge below 25% before repairs and upgrades to reduce the risk should you short or physically damage the battery, but they also recommend enabling Storage Mode in order to ensure the Deck is fully powered down, to avoid damage to the electronics.
Lithium batteries usually needs to be stored at around 50% SOC, however when you want to store such a battery, you also have to keep in mind the self discharge rate, and the fact that once over-discharged (even through self discharge) a lithium based battery could be dead and should never be recharged as it could burst in flame. That's why 60-65% is a good choice, as it will allow you to store it a lot longer without reaching over discharge state.
Help! I followed these instructions to a T and also replaced my SSD following that guide to a T and now I'm presented with this message:
"Default Boot Device Missing or Boot Failed. Insert Recovery Media and Hit any key
Then Select 'Boot Manager' to choose a new Boot Device of to Boot Recovery Media."
I don't know what any of this means and I can't find a single straight answer anywhere.
You need to install an OS.
See Valve's instructions - https://help.steampowered.com/en/faqs/vi...
Rich -
Does battery storage mode mess with the files in anyway. Im having an issue with the deck and steam support suggested putting it in battery storage mode then turning it back on but i have non-steam games that aren't connected to any server so if the files get messed up the save data is basically just gone permanently.
Battery Storage Mode just locks out the Deck's power supply until it is recharged. It does not affect any files.
If you swap your SSD you'll want to back up any old files first from the old SSD, or failing that obtain a USB adapter and boot your PC into Linux (or a Linux VM) to retrieve the files from the old SSD.
my battery can only fill until 6%, how can i fix it?
Good morning, I'm having a problem with my steam deck, it simply stopped loading and the light that indicates it is loading is not turning on. When it was still on, it showed that it was charging but it wasn't and it ended up unloading
помогите лазил в bios че то там на крутил и теперь при входе в bios не работает не кноки не сенсер, рестарт и тд не помогает. ну в самих играх и виндус 11 кнопки все работают как сделать bios обратно как все было? я зайти в него могу а переключать не чё не могу
If you followed the directions to a T you would of seen the part where they explain that you need to install a recovery OS they explain that steps once in the begining and once at the end.
Confirmed that this restored to my Oled Deck its ability to recognize the stock charger and start charging the battery again. Will it last? How did i get here in the first place? i do not know. But randomly the charger stopped actually charging and would light the light when plugged in, and would be somewhat recognized in desktop mode, but it said "not charging". I'll update here if something about this made things worse somehow. So far so good, the battery level remained the same before doing this, and is now up a few percent.
Столкнулся с проблемой недозаряда. Ни при каких уловках не заряжался steam deck oled выше 77%. Помог только финт с включением баттери сейв мод через биос. Остальное было бестолку
I follow the guide to a T and even after entering battery storage mode it still boots up after tap the power button once, I've tried several times and I'm afraid to try and swap my ssd over if it doesn't actually remain in battery storage mode.
My battery isn't charging past 2% and states over 100 hours to be fully charged yest it still hasn't progressed past 2% after three hours of charging. This is with the 15w steam charger.
Probably months late, but if someone else is in that case, maybe read https://www.reddit.com/r/SteamDeck/comme...
