How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Heat the rear glass: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Slice the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Slice the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Slice the adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Slice the adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Slice the adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  5. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
  7. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Remove the rear glass: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Remove the rear glass: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rear glass.
    • Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape. After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  8. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Unfasten the motherboard cover screws: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the eleven 3.9 mm-long screws securing the motherboard cover.
  9. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Pry up the motherboard cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Pry up the motherboard cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick underneath the left edge of the motherboard cover.
    • Flip the opening pick sideways to pry up the motherboard cover.
  10. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Remove the motherboard cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Remove the motherboard cover: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
  11. How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Disconnect the battery cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Disconnect the Battery in the Xiaomi Redmi Note 9 Pro, Disconnect the battery cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
238.180 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022.173crwdne2935297:0
crwdns2942667:0crwdne2942667:0 113
