How to Detach the Keyboard on a Surface Book
crwdns2942287:0crwdne2942287:0Follow this guide to safely disconnect the keyboard base from the display on a Microsoft Surface Book.
The Surface Book’s keyboard base is magnetically attached to the screen and needs to be manually detached if the device can’t power on. Detaching the display from the keyboard base is a helpful prerequisite, making repairs significantly easier.
- Paper Clipcrwdns2942747:0crwdne2942747:0crwdns2943225:0crwdne2943225:0crwdns2931591:0Amazoncrwdne2931591:0
crwdns2944105:0crwdne2944105:0
Press and hold the Detach button on the keyboard.
Alternatively, click the Detach icon on the right-hand side of the Windows 10 taskbar.
Remove the display.
Flip open the display as far as it will go.
Lift the device up and place it on its side, with the display facing away from you and the SurfaceConnect port facing up.
Straighten out one section of a paper clip.
Insert the straight end of the paper clip at a 45 degree angle into the sixth hole from the left.
Firmly push the paper clip into the hole.
Pull the base away from the display to detach it.
You should feel slight resistance when pressing against the internal lever arm. If you don’t feel the resistance after about half an inch, back out and try again. Be careful not to push the paper clip too far, as it can scratch the screen bezel from the inside, leaving a visible mark.
This doesn't work on mine... there's a 90° metal support bracket that covers the entire corner (goes up to about the 8-9th hole on the side) and blocks any & all access to the screen release mechanism. After seeing this "solution" online so many times, I never understood how this worked for anyone else...
I could detach mine following these instructions. When inserting the paper clip you will feel a resistance like pushing a spring. In my case, pushing the paper clip in about 5 millimeters and holding it when I hear a "click" sound. Be sure to grab the tablet when you see it separating (or have at hand a plastic spudger or opening pick to avoid snapping into place again due to the very strong magnets present).
Bonjour,
J’ai suivit les indications telles qu’elles et cela fonctionne parfaitement !
Appuis de « haut vers le bas avec angle de 45deg) comme expliqué.
Merci pour l’astuce. Cela ma permis de me rendre compte que la batterie derrière l’écran n’était pas hs. Apparemment un problème de connexion « clavier-tablette ».
With one side detached, pull firmly to pivot the display out to disconnect the second side.
Remove the display.
To reattach the display, align the magnetic connectors and allow it to snap into place.
Procedure didn’t go as planned? Check out our Answers community for troubleshooting help.
crwdns2935229:010crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Yesss !
Respect !
Hello,
Thank you for this tutorial.
Do you know if it works also for the latest Surface Book 3 in 15 inches size?
merci beaucoup ce tutoriel m'a été très utile
Merci beaucoup pour ce partage, très utile!
Excellent travail!
These instructions are clear and concise - Worked perfectly! 5 stars out of 5! Thanks!
Your process made this easy. Microsoft product design team needs to be fired for this horribly painful process to detach.
you are brilliant, very good and thank you so much
