How to Clean Corroded Battery Terminals
  1. How to Clean Corroded Battery Terminals, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
    • If your device still works, power it down completely before starting.
  2. How to Clean Corroded Battery Terminals, Remove the batteries: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove the batteries: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove the batteries: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the batteries from your device.
    • If there's a lot of corrosion, the batteries may be stuck in their recess. Don't try to force them out...unless you're a small, green, force-sensitive creature.
    • If any batteries are stuck, follow the next step as normal to clean around them.
  3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Anti-Static Brush
    $2.99
    • Use a toothbrush or anti‑static brush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
    • Use the point of a spudger to pick out any bits that are stuck.
    • Pick around the batteries, and not at the batteries themselves.
    • Flip your device over and gently shake out the loose corrosion and debris.
    • Dispose of the corrosion and debris in the trash.
  4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove any stuck batteries: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You should now be able to remove any batteries that were previously stuck.
    • Clean out the battery recess with a toothbrush.
  5. How to Clean Corroded Battery Terminals, Clean the terminals: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Clean the terminals: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Clean the terminals: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
    • Lightly dip a cotton swab in white vinegar or lemon juice.
    • Don't soak the cotton swab. Only use a small amount of liquid at a time.
    • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
    • The corrosion may fizz and bubble. Don't worry, this is normal.
    • Continue this process until there's no corrosion on the terminals.
  6. How to Clean Corroded Battery Terminals: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Microfiber Cleaning Cloths
    $3.99
    • Isopropyl alcohol will remove any residue left from the previous step.
    • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
    • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
    • Wipe the residue away with a microfiber or lint-free cloth.
    • Repeat this process until the terminals are completely clean.
    • Wait two minutes to allow any residual alcohol to evaporate.
  7. How to Clean Corroded Battery Terminals, Install new batteries: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Install new batteries: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Install new batteries: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
crwdns2935229:05crwdne2935229:0
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119,779 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,014crwdne2935297:0
crwdns2936751:024crwdne2936751:0 80
crwdns2936753:07crwdne2936753:0 558
crwdns2936753:030crwdne2936753:0 1,958
crwdns2942667:0crwdne2942667:0 34,444
