How to Clean Corroded Battery Terminals
    1. How to Clean Corroded Battery Terminals, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
      • If your device still works, power it down completely before starting.
    2. How to Clean Corroded Battery Terminals, Remove the batteries: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove the batteries: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove the batteries: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the batteries from your device.
      • If there's a lot of corrosion, the batteries may be stuck in their recess. Don't try to force them out...unless you're a small, green, force-sensitive creature.
      • If any batteries are stuck, follow the next step as normal to clean around them.
    3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Anti-Static Brush
      $2.99
      • Use a toothbrush or anti‑static brush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
      • Use the point of a spudger to pick out any bits that are stuck.
      • Pick around the batteries, and not at the batteries themselves.
      • Flip your device over and gently shake out the loose corrosion and debris.
      • Dispose of the corrosion and debris in the trash.
    4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Clean Corroded Battery Terminals, Remove any stuck batteries: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • You should now be able to remove any batteries that were previously stuck.
      • Clean out the battery recess with a toothbrush.
    5. How to Clean Corroded Battery Terminals, Clean the terminals: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Clean the terminals: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Clean the terminals: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
      • Lightly dip a cotton swab in white vinegar or lemon juice.
      • Don't soak the cotton swab. Only use a small amount of liquid at a time.
      • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
      • The corrosion may fizz and bubble. Don't worry, this is normal.
      • Continue this process until there's no corrosion on the terminals.
    6. How to Clean Corroded Battery Terminals: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Microfiber Cleaning Cloths
      $3.99
      • Isopropyl alcohol will remove any residue left from the previous step.
      • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
      • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
      • Wipe the residue away with a microfiber or lint-free cloth.
      • Repeat this process until the terminals are completely clean.
      • Wait two minutes to allow any residual alcohol to evaporate.
    7. How to Clean Corroded Battery Terminals, Install new batteries: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Install new batteries: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Clean Corroded Battery Terminals, Install new batteries: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
crwdns2935229:021crwdne2935229:0
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
200,085 crwdns2915208:0crwdne2915208:0
crwdns2935297:01,243crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:084,436crwdne2935297:0
crwdns2936751:024crwdne2936751:0 59
crwdns2936753:07crwdne2936753:0 481
crwdns2936753:030crwdne2936753:0 2,144
crwdns2942667:0crwdne2942667:0 72,576
