How to Check Your iPhone's Battery Health
  1. How to Check Your iPhone's Battery Health, How to Check Your iPhone's Battery Health: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • In order to proceed with this guide, your device must be running iOS 11.3 or higher.
    • Open the Settings app.
  2. How to Check Your iPhone's Battery Health: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Scroll down and select Battery.
  3. How to Check Your iPhone's Battery Health: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Select Battery Health.
  4. How to Check Your iPhone's Battery Health: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new.
    • Over many charge and discharge cycles, this number will gradually drop.
    • Your iPhone should continue to work fine, albeit with shortened battery life. Apple typically recommends replacing the battery once it degrades to 80% or lower.
  5. How to Check Your iPhone's Battery Health: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Check Your iPhone's Battery Health: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Check Your iPhone's Battery Health: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peak Performance Capability tells you whether your battery can still supply sufficient power for the iPhone's most intense processing tasks. Normal peak performance is what you're aiming for.
    • If it says your iPhone has experienced an expected shutdown, that means your battery couldn't supply the needed power quickly enough, and the system shut down as a result.
    • Your iPhone will throttle its own performance—slowing itself down—in order to prevent further unexpected shutdowns. This can be disabled to manually enable peak performance.
    • Once you disable performance management, you cannot enable it again. It is automatically enabled after an unexpected shutdown.
    • Once your battery falls below a specific threshold (typically 80%), you will be notified that your battery's health is significantly degraded.
    • Follow this guide to replace your iPhone X battery, or click here for other iPhone models.
That's all folks!
crwdns2935229:028crwdne2935229:0
Josh M
crwdns2935283:011/24/14crwdne2935283:0
913 crwdns2915208:0crwdne2915208:0
iTech West Palm Beach crwdns2935289:0iTech West Palm Beachcrwdne2935289:0
Business
Battery Health no funciona con las baterías iFixit.
Cambié la batería de mi iPhone 6 por una batería iFixit y no se puede ver el porcentaje de batería máximo. Aparece “reparar“.
Con alguna aplicación de análisis de batería muestra 98%.
Jairo Ochoa - crwdns2934203:0crwdne2934203:0
Under “Battery Health,” my iPhone SE says only “Service” and gives none of the information listed here.
Jeremy Nichols - crwdns2934203:0crwdne2934203:0
Most likely your battery is below the recommended threshold and should be replaced.
If you replaced your battery, it may continue to say “Service”. I would recommend using a computer app like coconutBattery to check.
Josh M -
mine iphone 6 cannot watch battery health
gfght - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 62
crwdns2936753:030crwdne2936753:0 225
crwdns2942667:0crwdne2942667:0 13,192
