How to Calibrate Gimbal on DJI Mini 3 Pro
crwdns2937549:0crwdne2937549:0
Arty
crwdns2935283:010/27/19crwdne2935283:0
28,096 crwdns2915208:0crwdne2915208:0
crwdns2935297:095crwdne2935297:0
crwdns2947412:023crwdne2947412:0
The software doesn't list mini 3 pro as one of the supported drones. How to go about it?
Rakesh Menon - crwdns2934203:0crwdne2934203:0
waiting for software update
Arty -
I have seen posts where people have used code from Mavic mini 1st series to mini 2 or mini SE and the calibration process was successful.
Arty -
This guide is not suitable for Mini 3 Pro. For now, it's impossible to recalibrate the gimbal on Mini 3 Pro without specialized authorized software.
Anton - crwdns2934203:0crwdne2934203:0
Mavic 3 is already supported, probably Mini 3 will be supported in the next update.
Arty -
Does the DJI firmware tools file updated as they come out with updates, i have a mini 3 pro replaced a broken gimble cable, no use of gimble now. I don't want to fry my drone by trying this with a different drone code, has anyone done this gimble calibration with the mini 2 drone code? How can i stay up to date on the firmware tools to know when this will work for the Mini 3 pro
Corey Oliver - crwdns2934203:0crwdne2934203:0
Any news about when mini pro 3 is supported?
Sagi Morhaim - crwdns2934203:0crwdne2934203:0
I can calibrate mini 3 Pro / mini 4 Pro gimbal remotely, you can write me on whatsapp +62 821-7276-9186 or telegram @djianderson
J Anderson -
I can remotely fix DJI Mini 2 Error 40011 after change gimbal. It will take about 45 Min to finish. Fast and Easy with Reasonable Price.
You don't need to Send your Drone to Service Center, it will spend few days to get your drone back and i will cost more. For me, I Just use Teamviewer to remote your Desktop and Forward DJI VPN to your PC. Easy Solution and Fast. Telegram / Whatsapp : +85589898982 Name: DJI Solution
Yin kaoang - crwdns2934203:0crwdne2934203:0
Hello, It is not possible for Mavic Mini 3 Pro or Mavic 3. When connecting the drone to the PC no COM port appears, libusb appears. Is it possible that this is solved?
Michael Jordan - crwdns2934203:0crwdne2934203:0
Yin kaoang your what's app # doesn't work? Eric Dronesetc.us
Eric R - crwdns2934203:0crwdne2934203:0
Are there any updates on The DJI MODEL CODES specifically for Mini 3 Pro? I've been searching for many days but i don't get it.... Please help me to solve this problem
Hamrizki Studios - crwdns2934203:0crwdne2934203:0
Compre un dji mini 3 pro usado y sin su respectivo control, cuando lo pude emparejar con el control me salía un aviso de una cantidad de vuelos y después de eso ya no es posible volarlo porq dice q sigue asociado a una cuenta con el otro control pero no puedo contactar a quien me lo vendió, alguien sabe si se puede hacer algo gracias
Cristian Cruz Toro - crwdns2934203:0crwdne2934203:0
Any update on if support for the Mini 3 Pro is available???
Kevin Grooman - crwdns2934203:0crwdne2934203:0
Hi can any one help me ... When I connect the mini 3 pro to the PC windows 10
Windows read it like a harddisk and I can't read it in serial port
Thank you 😊
Emad Mohtar - crwdns2934203:0crwdne2934203:0
https://youtube.com/shorts/HqTn7C4Oedo?f... If u are looking for calibration. Paid service available. This is the link to my youtube short.
Prabhjot Singh -
My gimbal came unplugged and now says it's stuck
TAD - crwdns2934203:0crwdne2934203:0
This tutorial is outdated. None of the commands will execute. Don't bother installing Python from externall sources if you are not familiar with all of this, instead use Microsoft Store, install Python. For pyserial, use pip command 'pip install pyserial'.
a good guy - crwdns2934203:0crwdne2934203:0
I can remotely calibrate mini 3 pro or any other dji models gimbal after replace, write me on whatsapp +62 821-7276-9186 or telegram @djianderson
J Anderson - crwdns2934203:0crwdne2934203:0
mini 3 code please guys
Mera - crwdns2934203:0crwdne2934203:0
Can someone help me calibrate a DJI Mini 3 Pro after gimbal repair
Rai Singh - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 50
crwdns2936753:030crwdne2936753:0 238
crwdns2942667:0crwdne2942667:0 18,429
