How to Apple MagSafe2 Power Adapter
  1. How to Apple MagSafe2 Power Adapter, How to Apple MagSafe2 Power Adapter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Apple MagSafe2 Power Adapter, How to Apple MagSafe2 Power Adapter: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Apple MagSafe2 Power Adapter, How to Apple MagSafe2 Power Adapter: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Что бы разобрать Т коннектор нужно срезать провод отступив 1 см от коннектора.
    • Выдернуть остатки провода
    • Взять железный стержень 4-5 мм в диаметре и выбить через отверстие провода внутреннюю часть разъема
    • Удобнее всего это сделать в маленьких тисках
  2. How to Apple MagSafe2 Power Adapter: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Apple MagSafe2 Power Adapter: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Из за ударных нагрузок внутренняя часть обжимки прогнется. Ее необходимо вернуть в исходное состояние.
    • Это легко сделать обычной отверткой.
    • ВНИМАНИЕ! Не повредите smd светодиоды и резисторы.
    • После этого необходимо припаять обратно металлический корпус к плате
    It was very difficult to do.
    once extracted the metal shield (i did it with a small torx (on the whole of the cut wire) and a hammer).
    then you have to push out the wires left in the tube .where there is the red cross on the picture
    after i left 1 mm on the inner wire and 5mm of the outer wires.
    it was very hard to tin solder the inner wire to the little silver plate (which is on only one side / under the center of the red cross of the pic )
    once by miracle the inner wire was soldered to that part. the 5 mm outer wires were already wrapped around the inner wire with 2 mm gap between them.
    you push a many outer wires as you can inside de metal tube and solder them to it. not too much to be able to push the metal shield back. Test if it works. put the shield back. It will not enter back completely but it s ok. it works again . some glue gun, electrical tape and it does it s job.
    philippe_ruth - crwdns2934203:0crwdne2934203:0
  3. How to Apple MagSafe2 Power Adapter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Apple MagSafe2 Power Adapter: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Apple MagSafe2 Power Adapter: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Срезать поврежденный кабель и залудить
    • Внешняя часть - GND
    • Внутренняя - +14,5
  4. How to Apple MagSafe2 Power Adapter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Apple MagSafe2 Power Adapter: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Apple MagSafe2 Power Adapter: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Продеть термоусадку и внешнюю часть разъема на провод
    • Припаять провода
    • С завода GND просто обжимается железной частью, но я для надежности еще припаял
    • Собрать коннектор
    • Запрессовать его обратно очень легко маленькими тисками
    Oddly enough, I don't know how to fix that typo yet...
    Juan Garcia - crwdns2934203:0crwdne2934203:0
  5. How to Apple MagSafe2 Power Adapter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Apple MagSafe2 Power Adapter: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Нагреть термоусадку
    • Готово
turbozohan
crwdns2935283:011/10/19crwdne2935283:0
310 crwdns2915208:0crwdne2915208:0
crwdns2947412:05crwdne2947412:0
Thank you very much for this guide, also with the pictures. This was really helpful.
I would like to say, that the time required was a lot more for me, about 3 hours in total.
My cable fell apart and the cable coating came off, so I have applied a heat shrink sleeving first over the part of the cable without the cable coating, then another sleeving above the whole cable.
The connector was glued inside, so it was difficult to get off the cap and later to get rid of the old cable, which was still stuck inside. After drilling into the metal crimped part, I could remove the remainders of the old cable.
Now I'm really happy, that the cable is renewed and that it works well.
Joerg - crwdns2934203:0crwdne2934203:0
Is there a way to change the magsafe adapter into a type C? i have a spare type C connector with the pins so what im asking is if it's possible to solder the inner part of 14.5V and outer part GND into a type C connector
John - crwdns2934203:0crwdne2934203:0
Type C chargers have different voltages for their specific units so probably not a great idea to try ;)
livfe -
For me sadly this tutorial didn't work. My connector was also glue on the inside and circuit was covered with some sort of resin. I destroyed part of a circuit while removing remaining cable from the charging circuit. I later figured out that it would be better to salvage parts of charging cable that were still sticking out of magsafe 2 connector, connect them in wire and protect with heat-shrink tubbing. Maybe next time.
I still have to say thanks to the author of this tutorial, since I think repair is our hope out of grand consumerist culture.
I do hope my comment serves as a warning to fellow fixers when dealing with original apple chargers.
iripuga - crwdns2934203:0crwdne2934203:0
Step 4 greaterreliability > greater reliability ;)
livfe - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 78
crwdns2936753:030crwdne2936753:0 236
crwdns2942667:0crwdne2942667:0 9,352
