How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes
  1. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes, How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will see a cable attached to an Allen bolt.
  2. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen up the bolt with the help of Hex key set.
  3. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now, pull the cable as much as you can.
  4. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tighten up the bolt while you keep pulling the cable.
  5. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To center the caliper for a smooth breaking experience, loosen up the two bolts of the brake situated at top and at bottom.
    The bolts that are being loosened in the picture are the wrong bolts for this adjustment. These bolts attach the brake assembly to the frame.
    The adjustment bolts to keep the rotor centered between the disc pads have the heads facing up, and are just above the bolts pictured. The proper adjusting bolts allow the disc brake pads to move in the “cross bike” direction which is necessary for centering the rotor between the pads.
    Richard Lange - crwdns2934203:0crwdne2934203:0
  6. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now, put the brake on.
  7. How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How to Adjust Tektro Aries MD-M300 Mechanical Disc Brakes: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While putting the brake on, tighten up both the bolts.
    • You are finished adjusting the brakes!
    The bolts you indicate for adjustment are caliper to frame mounting bolts, NOT ADJUSTING BOLTS.
    The adjustment bolts are on top of the caliper mounting bracket.
    Please revise.
    Ian Rolfe - crwdns2934203:0crwdne2934203:0
Md Abdullah
crwdns2935283:007/03/21crwdne2935283:0
209 crwdns2915208:0crwdne2915208:0
York University, Team S2-G3, Melo-Thaiss Summer 2021 crwdns2935289:0York University, Team S2-G3, Melo-Thaiss Summer 2021crwdne2935289:0
YORK-MELO-THAISS-SU21S2G3
Dude, the cable is attached incorrectly. The cable routes up and over the little arm.
Grandy - crwdns2934203:0crwdne2934203:0
I need a replacement t25 bolt and square ribbed nut that is shown in step 4. Any help would be stellar.
gr8fuljqr - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 115
crwdns2942667:0crwdne2942667:0 6,048
