How To Replace Merangue 2-Line Engineering Scientific Calculator Battery
  1. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery, Calculator Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the calculator off by holding down the [Shift] button.
    • Then, press the [AC][OFF] button.
    • Always turn your calculator off before removing the battery to prevent potential malfunction.
  2. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the calculator so that the back case is facing you.
    • Use a Phillips #0 screwdriver to remove the single screw from the battery cover at the top of the back case.
    • Keep the screw in a safe place to use when replacing the battery cover later.
    • If the screw does not unfasten easily, do not force it to avoid stripping the screw. If the screw is already stripped refer to the How to Remove a Stripped Screw guide.
  3. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently apply pressure to the battery cover and slide it upward.
    • If it doesn't come off easily, try gently wiggling it but do not use excessive force.
  4. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic spudger between the two batteries.
    • Use the plastic spudger to gently pry out the left and right batteries.
    • Do not use metal spudgers, as they can damage to the battery.
    • Do not use force when prying out the batteries to avoid damage.
  5. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put on the nitrile gloves and remove the two batteries from the battery compartment.
    • To dispose of the battery properly consult the How to Recycle End-of-Life Electronics article.
    • Always wear a pair of gloves prior to handling the battery to reduce the risk of chemical burns.
  6. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Inspect the battery compartment for any sign of alkaline residue.
    • If the area is clean, skip to step 8.
  7. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Dab a cotton swab in distilled white vinegar.
    • Gently clean the battery compartment in an up and down motion with the cotton swab.
    • Allow the compartment to dry completely for approximately two minutes before inserting the new batteries.
  8. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the new LR 1130 batteries in both slots.
    • Make sure the + sign on the battery is facing down in its respective slot.
  9. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the battery cover back into place.
    • Use a Phillips #0 screwdriver to secure the battery cover screw.
  10. How To Replace Merangue 2-Line Engineering Scientific Calculator Battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reset the calculator by pressing the [ON] button.
    • Release the [ON] button and press [Shift].
    • Release the [Shift] button and press the [MODE] button.
    • Release the [MODE] button and press the [3] button to reset all.
    • Release the [3] button and press [=] to confirm the action.
    • Finally, release the [=] button and press the [AC] button to complete the reset.
You have now successfully replaced the battery of a Merangue 2-Line Engineering Scientific Calculator.
Lakshan.14
crwdns2935283:007/02/24crwdne2935283:0
208 crwdns2915208:0crwdne2915208:0
York University, Team N-27, O'Regan Summer 2024 crwdns2935289:0York University, Team N-27, O'Regan Summer 2024crwdne2935289:0
YORK-O'REGAN-SU24SNG27
crwdns2942667:0crwdne2942667:0 376
