How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20)
  1. How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20), How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the gearing to the 4th position on your shifter.
  2. How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the alignment indicators on the right side (chain side) of the gear hub.
    • If you see two alignment indicators already aligned, your bike is already perfectly tuned!
    • If you can only see one indicator (as in picture 1), then your shifting is far out of alignment.
    • Flip the bike and check the underside indicator.
    • If the indicator closer the the wheel is further from the front of the bike, tighten the cable.
    • If you can see two indicators in the window or the underside indicators are within a quarter inch of each other, then skip to Step 5.
  3. How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shift to the lowest gear.
    • Insert a 2.5 mm hex key into the hole on the shifting mechanism and pull the shifter counterclockwise to relieve tension in the cable.
    • Carefully remove the cable from the shifter.
  4. How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a set or combination of pliers and/or wrenches to loosen the cable nut.
    • Rotate the two halves of the cable nut in opposite directions, turning the half facing you counterclockwise.
    • If the cable needs to be tightened, pull the cable nut away from the end of the cable. If the cable needs to be loosened, pull the cable nut toward the end of the cable.
    • Use a 2.5 mm hex wrench to pull the shifting mechanism counterclockwise again.
    • Insert the cable nut into its slot, ensuring the cable sits snugly against the shifting mechanism. Slowly ease pressure off the hex wrench.
  5. How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the alignment markers are close to each other, adjust the screw on the shifter to fine-tune the cable tension.
    • Loosening the screw tightens the cable, while tightening the screw loosens it.
  6. How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How To Adjust Shimano Nexus 8-Speed Internal Gear Hub (SG-8R20): crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the adjustment screw reaches its limit—too loose and nearly falling out, or too tight to turn—return to Step 3.
    • If the alignment markers are perfectly aligned, the shifting is correctly set.
Take your bike for a test ride! If the gears feel easier to shift or you cannot reach a higher gear, readjust the shifting and make sure the cable nut is properly tightened.
Jadon Lee
crwdns2935283:006/10/25crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 1-3, Kapoor Summer 2025 crwdns2935289:0Austin Community College, Team 1-3, Kapoor Summer 2025crwdne2935289:0
AUSTINCC-KAPOOR-SU25S1G3
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 209
